fpr question. please help
Old Aug 12, 2011 | 11:38 AM
4SFED Z's Avatar
4SFED Z
Default fpr question. please help
My tuner set base at 60, which don't know if true, I have a digital that eeads 65-67. My car is running 8.5 pounds of boost. At 5200 rpm fuel pressure drops off. I have an a and a external fuels system, increased the octane (tuner recommended) and I am NOT boost refrenced.
Should I adjust screw to increase the fuel pressure? This would make an increase straight across the rpm range right?
Should I boost reference? How?
Thanks for answering. I am sure its a noob question for most, but experience with all this is relatively new.
Thanks in advance.
NastyZ
Old Aug 12, 2011 | 11:58 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Thanks in advance.
NastyZ
Which FPR are you using?
Thanks,Matt
Old Aug 12, 2011 | 12:03 PM
4SFED Z's Avatar
4SFED Z
I will call u matt
Old Aug 12, 2011 | 12:04 PM
madmatt9471
I will call u matt
Okay!
Thanks,Matt 661-406-7516
Old Aug 12, 2011 | 12:53 PM
4SFED Z's Avatar
4SFED Z
Thanks matt. Will let you know how it goes. What's max/min for:
1. Idle fuel pressure
2. WOT fuel pressure
Old Aug 12, 2011 | 03:02 PM
madmatt9471
1. Idle fuel pressure - 58 - 62 max at idle with the Vacuum line attached
2. WOT fuel pressure - It should go 1 to 1 ratio and will max at the Fuel Pumps actual pressure
Thanks,Matt
Old Aug 12, 2011 | 09:42 PM
4SFED Z's Avatar
4SFED Z
One additional comment. If boost referencing doesn't help, what next. Everything is new. Altenator perhaps? How u test that? Thanks
Old Aug 12, 2011 | 09:59 PM
madmatt9471
You should then separate the two fuel pumps from the -6 line and take them an Y them into a -8 Line and feed them into an aftermarket set of fuel rails and take a -6 into the FPR from rail!
Take your ALT to Autozone or Local Auto Store and have them load check it.
Thanks,Matt
To fpr question. please help
