nitrous guys please help
Old Sep 11, 2011 | 03:07 PM
didntdoit11's Avatar
didntdoit11
St. Jude Donor '12
Default nitrous guys please help
ok im hooking up a fjo controller and need a little help
1-for my wot am i going to be tapping in to the blue wire on the tps?
2- for my tach signal---where would i be getting that from
thank you
jason
Old Sep 11, 2011 | 03:20 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
thank you
jason
Yes Blue wire should be falling TPS signal. (don't forget to set it in the FJO as falling TPS.
2. You can use the green coil wire from the passenger side coil packs since you're already over there grabbing a TPS signal.
Old Sep 11, 2011 | 03:45 PM
didntdoit11
St. Jude Donor '12
thank you
would i be able to use the white wire under dash (found in search from 2003) Once you pull the lower pannel under the steering wheel, there is a bundle of wires on the left side that will have the pink tach wire in there. Thats where I hooked up my shift light to. Once you find the wire, probe it w/ a tester. Your tach needle should jump. Good luck.
thanks again
To nitrous guys please help
