Blower cam question
Old Sep 23, 2011 | 05:37 PM
skeeters65's Avatar
skeeters65
Default Blower cam question
I have an 01 Z06.
Looking to put a cam in it that will make good power now but also be blower friendly if I decide to put a procharger on it down the road..
Any suggestions and what I should expect for HP gains??
Old Sep 23, 2011 | 05:47 PM
jobberone's Avatar
jobberone
jobberone
Do it all at once or add the blower first. Personally if you've never had a FI car then I'd SC yours with either A&A or ECS and stay around 500 or so HP. That way you can avoid getting into the motor now and not have to modify your drivetrain much. Stock radiator ok, wheels ok, yada yada. Just add some sticky tires.
Or you can spend a lot and build a monster.
Old Sep 23, 2011 | 05:57 PM
skeeters65's Avatar
skeeters65
I understand what you are saying but the stock cam just sounds so weak. My last car had a Texas Speed Magic Stick 3. Real rough idle and sounded mean as hell.
I know that wouldnt be a good blower cam but was hoping for something in between.
Old Sep 23, 2011 | 06:20 PM
4SFED Z's Avatar
4SFED Z
A and A stage 2 cam here. Check out their website. I like it. Nice lope and is still very streetable. You don't want anything with a lot of overlap.
ECS and England Green also has nice blower cams.
Old Sep 23, 2011 | 06:30 PM
jobberone's Avatar
jobberone
jobberone
To get all you can out of a motor you need a decent cam. But in reality with FI all you need to do is turn up the boost. If you're trying to max out an engine then you need the cam and heads to do it. But it's cheaper to just turn up the boost. To get 550 HP you don't need to change your cam, heads, intake yada yada. Just throw a blower on it.
Now I will say I wouldn't do that myself. I have a forged bottom end. But plenty of people do it and you can expect your stock engine to live for awhile at low boost levels with a good tune as long as you don't beat the crap out of your car. I would also add meth to make your engine last longer.
There are many ways to do this.
If you're insistent of a mean lope then call ECS or I use Comp Cams. They should be able to dial you in.
I will say my car sounds relatively stock except for my exhaust although it has a little lope to it. Not very much. The overlap is different for a FI car compared to a badass NA one.
Old Sep 24, 2011 | 03:51 AM
QUIKSILVERZ's Avatar
QUIKSILVERZ
i am taking out my ECS n/a cam and installing an LG G5xB camshaft this week. The only diff between the setups will be i am also removing my SLP UD pulley and putting a stock pulley backy on. BUT the car will be tuned/dynoed by the same tuner. The ECS cam and UD pulley made 428/365 at the wheels. You dont see many blower cams in n/a setups much on here but i will post up my results next week.
CAR
2002 z06, 1 7/8" ARH headers, 3"x3" ORX, and vararam cai/powerduct
Old Sep 24, 2011 | 07:18 PM
BLACK 01Z's Avatar
BLACK 01Z
I have a 01z, had the ECS blower cam installed with a set of double springs, with the intention of adding a novi 2000 next spring.
Going in I was making 380/380 with Lg pros, Vararam, and a tune,
after I made 410/395. Sounds great, idles nice and drives like stock.
Old Sep 25, 2011 | 01:08 AM
a/c man's Avatar
a/c man
my blower cam is a comp cam 228/230 581/588 on a 115 nice lope not big but it makes 900rwhp! is a comp cam 54-444
Old Sep 25, 2011 | 02:26 AM
joshtownsend's Avatar
joshtownsend
Blower cam?? whats that? Wait that's where they take the same cam and mark "blower" on it and charge $75 more. Just make the most out of a NA motor, then put the blower on it.. 113LSA or lower.. that's if you want to go fast..
BTW.. anybody now where i can get my push rods tuned at?
Old Sep 25, 2011 | 02:56 AM
a/c man's Avatar
a/c man
whats the specs on you blower cam brother?
Old Sep 25, 2011 | 03:55 AM
a/c man's Avatar
a/c man
not trying to hijack this thread but what do you all think about this other blower cam i have new in the comp cam box its
216/230 @ .050
579/572 on a 118 lobe sep.
I was thinking about trying it out!
Old Sep 25, 2011 | 05:58 AM
stevieturbo's Avatar
stevieturbo
216/230 @ .050
Should be nice and smooth and work great. Easy on the valvetrain too.
The truth of the matter is, a mild cam will give good results everywhere with a blower.
So it's more down to personal choice about idle, fuel economy, emissions, power delivery, ultimate rpm than actual power.
If you spin the blower the same speed, boost and graph may take a different pattern, but overall power will not change much IMO.
I recently swapped from EPP's old cam 232/240 on 115 to the Lingenfelter GT9.
I wanted a totally smooth idle, and needed to clean up emissions for the yearly test here. And was hopeful this cam would run nicely to 7k too which the previous cam seemed to struggle with.
All goals achieved, and I dont feel power has changed at all, just power delivery is smoother and less aggressive. Which sees better traction too.
Time will tell how the valvetrain stands up to the big lift though, as that is a bit of concern for me..
Old Sep 25, 2011 | 12:18 PM
joshtownsend
I think i have it qapped at 41.5 with a psi at 52... that's just before TDC with a DA of 700
Old Sep 26, 2011 | 12:20 PM
95vettski's Avatar
95vettski
227/235 113+3 will work well and provide a lumpy idle.
Old Sep 26, 2011 | 04:52 PM
MJD's Avatar
MJD
Crane cam here, 222/228 .551/.551 lsa115 Good street manners, shakes the car just a little. I run 1.8 roller tip rockers to bump the lift a bit.
To Blower cam question
