What should I look for in a boost cam? Im about 450 whp hc e85 m6 car right now.
My current cam is 228 232 595 574 114 lsa
Im looking for 600 whp w room to grow to 800 in the next few years.
I have a a and a P1sc kit going on soon.
Man give Arun a p.m. in here he is a vendor in here from up north. He has played with more cams in these F/I set up than any one I know plus most if they really have a really kick azz cam will not give it out to other, he is not that way man. Robert
I agree with 4SFED Z. You should spend your money on springs and a fuel system. You may want to add a large radiator. You will need to consider drivetrain upgrades.
racetronics rewire kit, bkb bap and a 255 pump. 98 also has a return system thaqt seems to support more rwhp.
You should be OK then. How are your springs? Be the judge of that. IF they are factory, shange them. Definately look into a meth kit for insurance. Just dont get a meth dependent tune in case the crap fails
comp cam has a bad a$$ one that im looking at they say you want the ex bigger to let it all out! and your cam is smaller on the ex lift! i really think you would gain with this camp blower cam is # 54-477-11 its 227/243 614/624 on a 114
. Just got new springs today pp gold 650 lift dual also running corn which has great cooling too but def in the future for a rad either way
but the duration is larger...reverse split cam
Originally Posted by black98c5
If you're trying to eventually hit 800rwhp, you might want to think about going straight to the D1sc.
I think your cam is ok but there are better blower cams like the one i suggested you will not see big #s if you change your cam. boost is where you will see big #s every pound of boost is 25 hp! change your cam and you will see 20 more hp thats all! the most I could get out of my P1 on a 402 was 700rwhp! to see 800 you will need bigger blower it takes a lot of parts and $ to get 800rwhp! good luck! have fun!
