retune or calibrate???
Old Oct 2, 2011 | 03:50 PM
lup302's Avatar
lup302
Default retune or calibrate???
I have stock map sensor i have to upgrade to a 3 bar map sensor and install it before i bring it to get tuned. My ? is could i just swap out i have the pig tail to splice in. Will the car start and drive with a different map sensor or does it need to be retuned or calibrated first???? we be changing pulleys to up the boost. Procharger all the way
Old Oct 2, 2011 | 06:52 PM
user_name's Avatar
user_name
The car isn't going to run with the 3bar. You should do it on site. If it is a 0-5v map sensor then wiring it up will be simple. I don't think they make one that plugs into the back of the intake though. Mine is inline.
Old Oct 2, 2011 | 08:04 PM
corvette8189's Avatar
corvette8189
around 50$
GM part # 12623671
plug and play
Old Oct 2, 2011 | 08:40 PM
lup302's Avatar
lup302
Default Thanks guys
I spliced into the harness. A T splice so i lefted the stock sensor on and t'ed off with the pig tail that i got with the 3 bar sensor, so when i get there i will switch sensors at there shop so i don't get dinged for 225.00 and i have to change two spark plugs anyway. Changed my injector to bigger ones and drowning the BR7 new plugs on cylinder 1 and 3 so easy change and moved map sensor also. Thanks i installed the 3 bar map and it started and idled but that was it. Give it a little gas and car dies. Just wanted to make sure. Thanks guys
To retune or calibrate???
