Have an APS C5 system installed on my C6. LG upgraded turbos, standard APS scavenge pump. Smokes at idle at times - especially when the oil gets hot. I run 20 W 50 oil in this thing. Sometimes it's not bad, other times I'm embarrassed.....makes 1000 hp and the freakin thing looks like its about to blow up.
Ive heard of people using the Exo pump. Does anybody have any suggestions? Louis says do not run restrictors, and I dont wanna starve the turbos anyway.....
OK. Are the -10's bigger than the ones APS supplies? Thanks again for the help. Did your car smoke intermittantly too at stop lights and stuff?
I forget how big the APS hoses were but mine were oil soaked and swollen a little. -10 is a good size to run, just don't run anything smaller.
Yeah, my car smoked terribly and this cured it.
Because my car is a C6 I was unable to mount it in the standard APS location. Had to move it forward and up between my intercoolers. Unfortunately, the car smokes HORRIBLY with the exa pump in this location. I'm at a loss.
Going back to the weldon and trying restrictors. What size is recommended?
TurboWerx exapump and good SS braided lines for draining and smoking will be gone.
He is right. The problem is with your scavenge If your car were working fine and this happen just now, I had it in my Gen 3 Dodge viper. Here is a link where to buy a good scavenge that can stop this smoke at Idle:
Update: I talked to a few people and found my restriction to be in the banjo fitting itself. By drilling out two holes in the banjo bolt to 17/64 it increased flow back to the pump. I run my aps pump in standard location with no smoke. These are upgraded turbochargers.
