need advice
CAN I ,,,use a manual tensioner or the new version of ECS tenstionr without any issue with teh breakage prone early power steering idler pully bracket.
I am kinda wanting to go with a manual tensioer..As the car dont get much use and i am a lunatic with maintenance.
oh,,,,corvette gurus,,advice.....this has only happened one time and it was only one slot back and only on the alternator..( I have the non clutch alt pulley)
I dont want a belt issue....ever.
thanks,
DO you have any tall lip pulleys??? ( BTW,,,if belt strech is the only issue,,,you can run a manual tensioner??? I have no problem checking belt tension as this is no daily driver for me. )
thanks, a lot,, at least its a easy fix for me.
