Heres my idea and Im open to all suggestions but im trying to keep it as simple as possible.
Basically I was running a RX performance catch can and still was developing leaks so I need to vent off more pressure
My idea- Delete the PCV all together- run a line off the Passenger side valve cover nipple Y it in to line off of the valley cover nipple then run a single line from the Y to a vented Moroso catch can.
Yeah I thought about that to- I have an 03- and the DS VC has a plug on the rear. Is that where I would do it from? If so how would you suggest I go about it... preferably pics
Any pics of how you tapped into the VCs? Id like to run something big like -8 or -10. -6(3/8) will work but seems rather restrictive.
The driver's side VC already has a hole in the rear of it, so I just went and found a fitting that would fit. On the passenger's side VC, I drilled and tapped a hole big enough for a fitting that is right dead center of the valve cover, but its on the small surface closest to the intake manifold.
Here you can see the drivers side silver fitting that has the AN fitting and hose attached:
Here you can see where the AN hose comes off the top of the VC and the vented catch can where the go:
What Moroso can did you get? And just so I understand youre not running anything else other than just venting the 2 VCs
Hell, I'm not sure which model number it is. I thought it was going to be aluminum, but turns out it was black plastic. It's still nice, though. I guess that's why it was relatively cheap LOL
I use a -12 moroso off my passanger side valve cover. Use a catch can with check valve off valley to tb. The we tapped off each valve cover with -6an to another moroso and took off the vent and welded a -6an male bung on it and ran it to the suction side of my blower. Pulls great vac. No seal problems. Just took the dongle off the other day for a belt change and the impeller to the YSI was perfectly clean. No oil intrusion.
Sounds pretty solid- I already ordered the parts to do it like Corvette-Chris though lol I was looking at running the McMaster Carr check valve and a catch can as you did but decided against it as the RX had 2 check valves and it still IMO let boost into the crankcase
We have done this since 06. Info is here on the forum. Hope it works out.
