Bottom line, who makes the best or where can I find a few to compair? Must have a designated pump and reservoir and prefer to have it activate off of boost of fuel prussure but
i want to see whats out there and which ones seem to function
Thanks!
Phil aka: Fizz
Ive installed quite a few different brands of meth kits, I just installed a Alkycontrol kit on my car and it's one of easiest I've installed and works great.
I have a Alky Control kit and I really like it and Julio is a
very knowledgeable about the in's and outs of meth injection.
Julio is the owner and designer of Alky Control. He's the Man!!
I did a different brand than most on the forum and installed an Aquamist HSF-3 Meth kit on my C5 Z06. Easily the best quality meth kit available imho. Not as easy to install as the Alkycontrol and snow kits but they are very sophisticated kits that even come with a flow gauge to monitor the injection as well. I think they are made in England?
First off, these cars aren't 2.0l turbo rice wagons, therefore they have a higher demand for flow. That means you should really pay close attention to the inlet hose diameter. What you're going to find is that AEM an Aquamist and Snow have small feed lines that don't support the kind of flow for many of our big boosted motors. If you're going with a stock boosted setup, you can certainly get away with it, however if you want any flexibility to be able to step it up in the future, you might want to consider the Alky Control kit.
Second, make absolutely sure you get a "progressive" system that varies the pump speed and line pressure relative to your boost levels.
