Msd 2351
Old Dec 12, 2011 | 08:01 PM
C5nNC's Avatar
C5nNC
Default Msd 2351
I have a V1 CTSV with STS turbo kit. I just had to replace my 2350 bap with a 2351. Anyone know what MAP to pump volt settings I should use. I have it set to 14 volts flat as of now which does nothing when boost is acheived.
Old Dec 13, 2011 | 09:31 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Those MSD volt boosters are unreliable at best. If you really need the extra fuel, I would get rid of it and get a Kenne Bell Boost a Pump. I can't imagine a much more crappy scenario than your booster causing your motor to fail.
If you're going to keep it then I and many of us crank them all the way up. We even remove the controller and short it out permanently so that it stay's maxed.
Old Dec 13, 2011 | 06:12 PM
Skunkworks's Avatar
Skunkworks
Doesn't MSD stand for Might Suddenly Die. Sorry had to .
Old Dec 13, 2011 | 06:40 PM
BLOWNBLUEZ06
Don't apologize. They earned it!
To Msd 2351
