I am trying to figure out why I am not getting any boost out of my supercharger. It is a Vortech V-2 T. I bought a boost gauge and I cant get it to move the car out of a vaccum at all. I saw maybe a 1psi movement at the most from it.
To tell you a little about the car it has 243 heads a Z06 cam. LT headers, fast intake, z06 exhaust.
I have checked everywhere from vaccum leaks found a few small ones but nothing has changed from fixing those. I doubt my belt is slipping that much. Im starting to wonder if I just need to do a rebuild on the supercharger. Anything else you think I could do before I try this? Thanks!
Have you tried to pressurize the gauge with some known pressure source to make sure it's working? Any chance you have a check valve between your vacuum/boost connection and your gauge?
sorry I was slow to getting back and this thread is kinda old. I had nothing connected to the sensor and it showed 0. I plugged the line that was ran from the brake booster to the boost gauge and it would always show a vaccum even in high RPMS it pretty much stayed the same. I took off the BOV and pushed the inside down and the spring seemed to make it pop right back up. Im pretty sure the BOV is good as it took a good amount of force to do. I guess The only thing I can do is pressurise the whole system and see if I can find any leaks. The car is having some charging problems too but I have that started in a different thread. And yeah its an old system 6 rib.
