right now im at 706rwhp at around 10-12 lbs of boost. I wanna up the boost as much as i can with out over spinning the head unit, do a fuel system that will handle more power, and retune. So how much boost can i realistically get out of the d1sc and how much power is the most i can make on 93pump + meth on a dynojet?? thanks
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
The items I would be concerned about are the Eagle crank and rods. What are they rated too? 800rwhp would be nice, but 700rwhp that stays together is nicer.
You have the capability with your set up, make sure you have the durability with your set up first though.
Feel free to stop in or call if you would like to discuss this farther.
I had a 346 with Weisco pistons 9.2 c/r dual nozzles 100% meth 3.85" and a 7.25" balancer, D1SC gave 15.5#, heads were AFR 225
805 rwhp SAE. The rods were stock, they let loose.
Ok sounds good..I wasn't sure if id be able to get 15lbs out of the d1sc.. I'm pretty confident the easier rotating assembly will hold together from past experience
Buddy look at what doug is telling you here, the eagle stuff I dont see holding together for you long with 800 plus rwhp. Robert
Hmm idk I guess I will check into it..my 408 with a f1r @ 24 lbs is around 1200rwhp eagle crank & rods, diamond pistons.we took apart to inspect and every thing was fine.only changed rings & bearings
Dam man I dont think my set up would hold this kind of boost are timing in her to put out and hold together. You have more ***** than I do.. Robert
Man all you guys making 800 plus on 347 ci make me mad. The tuner that tuned my car needs to learn how to tune. It's a 427 destroked to 387 on 13 psi and made 675 on an overly conservative tune with meth. I'm switching to a 3.4 blower pulley hoping for 18 psi and 800rwhp with out nitrous.
Something wrong with your set up in some way, That really should be doing alot better with a good tuner on it. Unless you are still on 6 rib set up and no flip drive on her. Then you are just at a lose but the tuner should be able to tell by your runs on the dyno if you are slipping at the belts...Robert
The problem is a horrible tune. Efi alchemy in Jacksonville, fl tuned the car for the previous owner. It has and ATI 8rib conversion with no belt slip. I just started a thread in here that has my full mod list ( can I run mid 9's on my setup) take a look at it and tell me what you think
I did last week I think I dont see it in the 9,s with a stick car, Unless you really just have a excellent run in it from the line all the way thur to the 1/4 mile. It has been done but not like in a A4 trans car in the vette.. Much easy to do in a auto set up that time after time. These dam cars just dont hook up at all that good.. Robert
