Window switch not working
Old May 11, 2002 | 03:44 PM
WA 2 FST's Avatar
WA 2 FST
Default Window switch not working
Got the nitrous done yesterday and fortunately we built in a "jumper" wire in case the WS didn't work.
Sure enough it didn't. This one has the appropriate wires spliced and the TNT installation instructions were followed exactly and double and triple checked. Spliced into the #10 pin (white wire) on the PCM (red harness) for the tach pickup.
Any opinions? Once I remove the yellow wire and ground the system (like you would if you didn't have the WS), everything operates perfectly.
This is on a '02 Z.
Old May 12, 2002 | 01:12 PM
jetskifast's Avatar
jetskifast
Default Re: Window switch not working (WA 2 FST)
If you are using MSD window switch. You need to set window switch, as 4 cylinder. Cut both end loop wires.
Old May 12, 2002 | 03:10 PM
WA 2 FST's Avatar
WA 2 FST
Default Re: Window switch not working (jetskifast)
Yes sir. That was done before the install. Still no dice. :(
To Window switch not working
