Harland Sharp rocker install ?
Old Jan 28, 2012 | 01:03 PM
a/c man's Avatar
a/c man
Default Harland Sharp rocker install ?
Ok I changed my stock rockers out for some harland sharps because they say with AFRs the guides are bronze and will wear out with stockers
it seems to have more valve train noise is this just the way they are? I checked my preload and its about the same as the stock ones
thanks for any info! I did a search and found nothing on the characteristic of the rockers
Old Jan 28, 2012 | 01:06 PM
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
How much preload do you have? Did you mark the valve tips and check to see where the rockers are riding on the valve?
Old Jan 28, 2012 | 04:20 PM
tlove32's Avatar
tlove32
Increased valvetrain noise is the norm for H.S rockers
Old Jan 28, 2012 | 05:25 PM
a/c man's Avatar
a/c man
about 1 1/2 turns from 0 lash no i have not checked the geometry yet!!
Old Jan 28, 2012 | 09:45 PM
robert miller's Avatar
robert miller
Buddy check it now and make sure you are riding close the the center for sure here. I have the T&D rocker shaft set up on mine and love them. I went with the T&D set up due to the extra oiling it gives up top dont think you can ever get to much... Make sure all you bearing on the rockers are good and no flat spots. But that is after you check the other 1st what Arun said...
Old Jan 28, 2012 | 10:57 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
My HS RR's are noisier than the stockers and it is the norm! But I like them!
It looks as if you have them set correctly
Thanks,Matt
Old Jan 28, 2012 | 11:00 PM
a/c man's Avatar
a/c man
Thanks,Matt
thanks matt that's what I was thinking just needed to get some info I rechecked them again and took a black marker to the valve tips and spun it over the rockers are hitting the center so they just make more noise
Old Jan 28, 2012 | 11:10 PM
madmatt9471
Yeah it is what it is - so what I did was apply some sound deadening on the bottom of the Fuel Rail Covers and that really seemed to redirect the sewing machine noise down - or lets say just muffle them perfectly
Thanks,Matt
Old Jan 28, 2012 | 11:36 PM
a/c man's Avatar
a/c man
Thanks,Matt
good idea too bad mine wont fit with my fuel rails my car is just so quiet with a stock catback I hear all the little stuff my wife said get over it your lucky it runs after what ETMCs did to us
Old Jan 29, 2012 | 06:59 AM
Lloyd Christmas's Avatar
Lloyd Christmas
Thanks,Matt
What did you use? Dynamat? Any heat issues?
Old Jan 29, 2012 | 08:44 AM
madmatt9471
Yes! That is exactly what I used and absolutely "NO" issues with heat at all and it muffles they real nice!
Thanks,Matt
To Harland Sharp rocker install ?
