HELP...centri FI build PLEASE !!!
It will have stock l92s, l76 intake and ls2 tb.
I am "planning" on running a D1SC and keep a "conservative" 650-700 rwhp to start with. 1st boosted car and i wanna get used to it first.
I am also planning to break the motor in with a mail order tune WITHOUT the procharger on it for probably 500 miles. then get a dyno turn when i add the procharger
questions:::
1. What fuel system would be recommended?? duel pumps, hot wire kit,injectors ???
2. I don't have to pin a Callies crank, right?( i wanna do it now if i do)
3. Is my break in process correct ?
4. will a Monster clutch stage 3 work for me? i already bought it but thinking about returning it.[/SIZE]
here is my thread i started if it helps at all
http://forums.corvetteforum.com/c5-t...post1579876336
thanks so much in advance to any help at all. i know alot of you guys have been though what i am going though so i figured this would be the best place to get some knowledgeable answers. i will continue to post questions as they arrise.
questions:::
2. You don't have to pin the crank but you run the highly risk of the balancer slipping in the crank hub due to the higher tension of the belt. Unless the crank has a key on the hub, but then you would need a balancer that has a slot for the key. I would not skip this .
3. I have a 347 D1SC that makes 750rwhp and I have a monster stage 4. So far I'm over the rated range for this clutch. I would call them and ask if you could send it back for an upgrade. I would get a stage 5 or 6 if I were you. I mean I'm already looking at the stage six for myself.
4. Ask the engine builder that they recommend. All I did was put about 4 hours of running time, a couple heat cycles, a couple of revs, and made sure everything was working correctly. Then trailered the car straight to the dyno with the blower and 18lb of boost. I think I put around 5 miles from driving it around the block.
Good luck with the build, you will love it!
Dual pumps is a must with upgraded/dedicated wiring for everything. You'll probably be looking at 80# injectors at the levels you want. Upgraded rails and lines would be recommended as well. Check out the A&A setup, not saying buy it, but it is a good layout.
Pin the crank, non-negotiable.
I would also take a look at twin disc options. I'm happy with my ACT twin disc. Very nice drive-ability and bite, but I'm only pushing 620rwhp and 550rwtq.
could i just run some 60-80lbs injectors while im breaking my motor in WITHOUT the blower ? I really dont feel like buying one set of injectors for NA break in and then buy another set when i add the blower.
http://www.summitracing.com/parts/SUM-C2501/?rtype=10
And I've thrown a turbo kit on a car with a stock tune and drove it with stock injectors to get tuned (staying out of boost)
