Apparently Intercoolers arent needed in FI??
Looking to hear more info on a very reliable system that wont kill a motor if the pump goes and has some type of fail safe.
to the OP I would want an intercooler
Just wondering, good info tho FYRARMS
For the record, I am not a fan of meth-only intercooling. I just know it is done often.
That is why I wouldn't run meth in any application, unless there was an integrated safety feature in the system. For example, in high-end stand-alone systems such as Motec and ProEFI, if the meth stops, the system instantly pulls timing or cuts boost pressure.
That depends on the volume of air that turbo is pushing. Not sure what size turbo he runs, but many single-turbo Toyotas (obviously his engine) will make 500+rwhp on the lowest boost setting and pump gas. I don't know what boost levels he is planning on running.
Could be any reason, really. Lack of space, no front grille opening, wants to be different, etc. Based on that picture, he has a problem with affordability, too.
PLENTY of cars that use alcohol as fuel (especially drag cars) run with no intercooler. Also a lot of low boost turbo/SC kits also come without an intercooler.
Also OP the car in that picture is probably faster than yours.
I said a DAILY driven car. A car that is solely dependent on meth with IAT's Lower then 130*? I couldnt see that being very probably. I wouldnt want a car dependent on meth as said above by other people, if that goes so can your whole motor. I plan on getting a 434 LSX, you think I want to take that kind of chance??
This was all a comparison to a boosted vette, Ive spent a damn good bit of time on this forum, I havent seen any non intercooled (besides maggie) high hp builds done on a vette that is used as a regular car. Where am I wrong? Did I once talk about a drag car in my first post? No because thats a different story.
So where Is my fail? this thread wasnt even about not using them in general, Im sure it can be done, but Im talking about reliability. Why'd ya have to come in my thread and spew nonsense like an ignorant child lol Whatever gets my wpm up I guess. You have any more to discuss with me, pm, Im not fouling up my own thread with nonsense. I know it can be done, but if its THAT good, why isnt every vette owner doing it? See my point??
My car isnt done yet but to give you an idea...
I have a lot more work but...........I think Ill be alright.
ps.. I've been saying intercoolers are not needed for a while..only in the vette world are they needed... i guess just for show
So to save me from mounting these damn A2W intercoolers, and finding out a good water pump and finishing my lines. What do you suggest?
Alky control is honestly that good? Im afraid (because I've heard this before) of a pump failing and in a couple seconds cyl. 5 went and motor was toast. I cant afford built motors left and right
I heard people on hear say they use "straight meth", my assumption was it just wasnt cut down.
So Im all ears
water cools the chamber
So, in theory... There is a mixture out there for everyone, example..
You can only run so much meth until it becomes useless.. so, say you run 2 M15 nozzles and spray 100% meth... That's 30 gals/hr but maybe your setup only uses say 16 gals a/hr to be efficient because of your fuel system and such.. You could run a 49/51 mixture of meth and water on the same setup and get some benefits of water injection. BTW water injection has been around since the 40's with old fight jets..
Anyways.. Meth is used for detonation control.. not necessarily to just cool the air charge... which is why some people run race gas or E85 instead of meth.
The key to understand if you need an intercooler or not is understanding what your trying to accomplish with it? When meth sprays, it cools the air charge down to roughly 75 degrees almost instantly. That's here in Houston when its 110 out here during the summer, no intercooler will ever cool any charge down to that temp or that fast. The only reason people say to use it is to keep the driving around IATs to maintain the PCM pulling timing when temps get higher then 145 or so from stock if i remember correctly.. You can change the tune and may it higher, say to 155 or so and never have a issue.. which is why intercooler are not needed for the most part... there are instants out there that an intercooler might be beneficial.. but most dont need it...
I will say this.. I do run a intercooler.. mainly because i'm to lazy to take it out.. but I run 2 m15 nozzles with 100%meth, making 26 psi of boost and i do it all on 87 octane going thru a aluminum intake.
Put it this way,
If you spray meth-you car just became meth dependant-because meth is fuel.
Plenty of cars don't run intercoolers-been doing it for years. Back in 97 when I was running a Novi 2000 we never used a intercooler. Made 20 psi and ran mid 9's@145+, drove the car everywhere-raced it all the time-used the 6BTM on pump and turned it off when we ran good fuel.
Just look at the NMRA Renegade and Real street classes, no meth, no intercoolers-the Renegade cars run low 8's and the Real Street cars run 9's.
Then you have alot of the old school blow through setups-one of the Fastest YSi setups runs no cooler and he's running 4.9's@140 with a YSi.
Depending on how you build the combo-I wouldn't be afraid to ditch the cooler-free up the radiator cavity-pickup the boost at was lost in the cooler and just spray meth.
So based on your alls experience, How much meth do you go thru? How reliable are these systems? How expensive is meth?
and What about Motec and PROefi as stated above?
