E85 or No E85
Old Feb 16, 2012 | 03:07 AM
Chrisrokc's Avatar
Chrisrokc
Default E85 or No E85
After seeing multiple E85 thread pop up and a onCue gas station (they carry E85) going in down the street from me, I am thinking about E85.
Come May I am doing a cam and re-tune. I will also have the A&A Fuel System installed by then (with KB boost-a-pump if need). The car has a V3 Si with a 3.8 pulley and methanol injection.
Question is, should I go E85? What type of benefits will I see power and reliability wise? Is it possible to tune for E85 and 91? During my reading I saw that 2004 models have the ability to add a sensor to the gas tank to detect what type of fuel is being used. This would allow for the car to swap timing and fuel tables on the fly correct? This would be a major plus if I got in a spot where I needed to run 91/93 without going full throttle.
Maybe I am crazy...
Old Feb 16, 2012 | 11:13 AM
dascorcha21's Avatar
dascorcha21
Here ya go this should answer most of your questions
http://forums.corvetteforum.com/c5-f...85-thread.html
Old Feb 16, 2012 | 11:42 AM
robert miller's Avatar
robert miller
He did one nice write up on E-85 for sure.... Robert
Old Feb 20, 2012 | 01:44 AM
Milan's Avatar
Milan
The answer is YES
Old Feb 23, 2012 | 06:06 PM
Slow Z06's Avatar
Slow Z06
my car loves it. The 10mpg i get on it, i however do not like
Old Feb 23, 2012 | 06:21 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
You won't be complaining about the exhaust stink with E85 for one.
Old Feb 23, 2012 | 06:24 PM
regorih's Avatar
regorih
Question
1. How do you supply your e85 to the car? Gas station or you have a supply at the house?
2. Is he car a daily driver......if so how many miles do you put a week on average?
3. Is the car on pure e85 or does I have a stand alone for e85 and runs on pump?
Old Feb 23, 2012 | 06:44 PM
Slow Z06's Avatar
Slow Z06
Originally Posted by regorih
Question
1. Pump
2. Daily - 220
3. straight e85.
Back on pump now to get fuel mileage back since i now drive 50miles one way to work
Old Feb 24, 2012 | 01:59 AM
dsmlights's Avatar
dsmlights
i can tell you that I love it. Like Bret said no smell what soever. It is hard on the pocketsa bit specially now that it is getting more expensive. but there is nothing like driving a 700
WHP car every day
Old Feb 24, 2012 | 05:37 PM
Z06supercharged's Avatar
Z06supercharged
12-14 mpg avg if im in 6th at 1500 rpms. Fun afternoon drives hammering hard I go through a tank in an hour easy.
Would never go back to anything other than E85 though. With E85 on a 105 degree day the engine and cooling system still thinks its 50 degrees out.
Old Feb 25, 2012 | 08:22 AM
Warp Factor's Avatar
Warp Factor
Ouch, that's worse than I expected, especially at cruise. I'd need to plan a long drive pretty carefully around fuel stops.
Old Feb 25, 2012 | 09:31 AM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
I'll probably be using E85 for my high-boost tune up. I see no reason not to since there is a station 10min from my house. I do have a 30gal Gas Caddy that I will use to store it in. On the flip side, I have no reason to use it as a daily fuel.
Old Feb 25, 2012 | 10:46 AM
Z06supercharged
Yes you do need to know where the stations are if going on a trip or really long drive.
You can refuel with non E85 on same tune and drive on that till you find E85 if need be and it wont hurt anything and will run just fine.
To E85 or No E85
