125 shot
Old Mar 5, 2012 | 08:59 PM
elerico's Avatar
elerico
Default 125 shot
can i run 125shot on my 04 LS1
K&N intake
TB bypass
Corsa exhaust
Diablo Tune
Bottler Heater
RPM window swithc @ 3000.
higher RPM cut off, standard shift point.
Tr6 plug gap at .035
I got two thing.. a tune with -6 degree or the IAT TRICK to run full power N/A and pull timing with n20
what do you think
will i blow my motor.
do i really need to run the tune or the IAT trick is fine.
Old Mar 5, 2012 | 11:18 PM
corvette8189's Avatar
corvette8189
anything can happen but you should fine
Old Mar 11, 2012 | 03:12 PM
McAllister513's Avatar
McAllister513
Be safe and get a tune. Nitrous is completely safe if your car is tuned right. I have never heard of the IAT trick so idk
I am spraying a 125 shot through a plate kit and my car runs perfect and just turned over a 100K so I say you will be fine.
Old Mar 12, 2012 | 02:45 PM
thechosenone's Avatar
thechosenone
Please get rid of those JUNK TR6's and pick up some NGK BR7EF.
Do you got a wideband and fuel pressure gauge?
With -6* of timing you will be fine and that is what I would do vs the other way. You should upgrade to Hp Tuners that way you can be 100% sure as your tune goes.
Old Mar 14, 2012 | 02:05 AM
Nitro Dave's Avatar
Nitro Dave
Like suggested above switch to the BR7EF spark plug. Personaly I am not afan of using the Iat to remove timing but many people do it.
As long as the tune up is right you should enjoy the added power with no issues.
Dave
To 125 shot
