nitrous window switch question
Old Mar 12, 2012 | 10:01 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Default nitrous window switch question
you guys running nitrous with a window switch, where did you tap in for the tach sensor wire to your switch?
Old Mar 12, 2012 | 10:47 AM
undertaker's Avatar
undertaker
From: ECS : WTF did you break now and HTF did you break it this time
For my shift light i went right off the ecm in the passenger fender....not positive on wire color/location though
Old Mar 12, 2012 | 10:57 AM
corvette8189's Avatar
corvette8189
right off the coil pack connector, i think the green wire ill check when i get home
Old Mar 12, 2012 | 01:02 PM
TheRadioFlyer
Supporting Vendor
I assume since the window switch is just looking for a signal, it doesn't pull enough current to affect engine operation? Does is matter which side of the motor I pull signal from?
Old Mar 12, 2012 | 01:31 PM
SargeZ06's Avatar
SargeZ06
Coil pack here as well. Nope didn't matter which side.
Old Mar 12, 2012 | 01:38 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
You have a pink, black, reference low and 4 other wires in the harness going to all of the coils The wire colors are purple, red, lt blu, and green. pick one of those 4 and tap it.
Old Mar 12, 2012 | 04:28 PM
TheRadioFlyer
Supporting Vendor
I assume each wire goes to a different coil then? SO it doesn't matter which one i pick?
Old Mar 13, 2012 | 12:34 AM
BLOWNBLUEZ06
Yes sir. Pick one and go.
Old Mar 13, 2012 | 05:53 AM
4SFED Z's Avatar
4SFED Z
I've heard of false readings from tapping coil pack location. I went to the fuse box located under the hood. Separate the box and look in middle section. #3 white wire is tach wire. Strip insulation and solder. Run wire through passenger grommet, behind radio and mounted box under driver dash.
4SFED Z
Old Mar 13, 2012 | 09:44 AM
TheRadioFlyer
Supporting Vendor
4SFED Z
Is there a corresponding fuse that could be tapped from inside the fusebox?
Old Mar 13, 2012 | 11:39 AM
4SFED Z's Avatar
4SFED Z
That I do not know. Its easy to get to and do. If you need you can call me. Shoot me a PM and I can give you my number.
Old Mar 13, 2012 | 09:21 PM
BLOWNBLUEZ06
I'm 99.9% sure that wire's not fused.
I've never had a problem with tapping the coil. You can also tap an injector.
Old Mar 13, 2012 | 10:40 PM
TheRadioFlyer
Supporting Vendor
I'm going to shoot for the #3 white wire under the fusebox. This should help keep the installation clean-looking.
Thank you all for your help.
To nitrous window switch question
