Pushing Coolant?
Old Mar 31, 2012 | 09:20 AM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Default Pushing Coolant?
I've noticed a some small coolant drips under the driver's side manifold the last few times I've driven the car, and just last night I noticed that some coolant was pooled up around the most forward, small head stud on the drivers side. I guess this may mean it's coming up through the bolt hole. Im not sure about the drips on the cradle, though. It's not spraying anywhere like I've seen other cars do, so I guess it could be from a larger bolt hole, too. Coolant temps area great and the oil is clean. Any ideas fellas?
Old Mar 31, 2012 | 10:07 AM
Corvette-Chris
St. Jude Donor '08
Mods can lock or delete this. I'm getting all the needed information in my build thread.
Old Mar 31, 2012 | 10:17 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Before it gets closed - when I would get it on the cradle it would drip out of the coolant tank and down the frame to the cradle!
Hope all works out well for you! Keep us posted!
Thanks,Matt
Old Apr 2, 2012 | 10:52 AM
Pekka_Perkeles's Avatar
Pekka_Perkeles
Typical seepage. Sounds cheap, but nearest gas station has all you need in their small portfolio...
Old Apr 2, 2012 | 11:03 AM
Corvette-Chris
St. Jude Donor '08
Huh?
Old Apr 2, 2012 | 01:28 PM
Pekka_Perkeles
Originally Posted by Corvette-Chris
Huh?
Yep.
This is what pro did say some years ago: "I do it with most of my aluminum engine installs to stop seepage. It won’t hurt anything."
These may look familiar, I guess, when I had similar experience..:
Old Apr 2, 2012 | 02:14 PM
Corvette-Chris
St. Jude Donor '08
I said "Huh" because I have no idea what you are talking about.
Old Apr 2, 2012 | 06:42 PM
madmatt9471
Wondering about clarification myself
Thanks,Matt
Old Apr 3, 2012 | 03:50 AM
Pekka_Perkeles
To clarify: any of these should help and are probably available in all gas stations..:
http://www.goldeagle.com/brands/alumaseal/default.aspx
I guess the irony here is that (for example) after somebody spending $15k for new short- or long block with lots of high performance parts and notices there's coolant leak, it's kind of funny that it is possible to fix it without spending another $1000 but with $10 or less..
Old Apr 3, 2012 | 07:52 PM
helga203's Avatar
helga203
O myyyyyyyy
To Pushing Coolant?
