Our FI Clutch Setups ?
So far i liked it except clutch pedal go all the way down to disengage, it definetly needed shim i measured .260" thought pretty good but heck nope, well sofar it held up pedal pressure slightly tigjter than stock but TICK MC will increase pedal pressure to some extent anyway.
You will be just fine with Monster 3 with your power level 650-675 Rwhp assuming 10 psi boost. Only thing i heard they glazed in street driven and make chatter again no real world experience.
If you dont race than ACT dual disk T01-G01 is pretty good too for $938 from thmotorsports.com pretty good deal for <1000 bucks bring it to me i will even install it for ya did 3 times sofar on jack stands getting faster on it ..lol.
Darion
If I were you I'd say give the McLeod RXT a try but don't go out drag racing too much on it.
If you don't want to try the McLeod, I'd say spring for one of those mantic clutches. I haven't heard anything bad about them yet.
At 550whp BTW...
Was in the market for a streetable clutch that held my power level and was pointed to the Monster III. I expressed my issues with my other clutches and the vendor quickly changed to the Monster 5 and said it would hold with no issues and was very streetable. NOPE - Chatters like hell, Called the MFG and they said i need to drive it more aggressively and it will stop chattering. I drive it to work and back, all highway, with some stop and go - not exacly an environment (with traffic) to be driving 'aggressively'. The real downer was when I took the car to the track late last year (only go once or twice a year), was frustrated with a run and hot lapped the car, clutch slipped out of the hole. So much for holding the power. I did bleed the clutch at the track, but not in between the runs.
I am sure the stock master/slave are to blame with alot of clutch issues seen, but i do not like being told something is streetable, when it really is not.
I am not very anxious to change the clutch again.... but i would love to see someone make some sort of adapter for the ZR1 dual clutch on a c5. i think that would fit most of the 'FI on Stock' people on this board.
I've got an RXT now with over 900rwhp. So far so good! Ironically it doesn't not make any noise at all.
I have heard great things about the Mcleod, but was told it was a bit overkill for my needs.
