d1 procharger
Old May 2, 2012 | 09:05 PM
safeandsound's Avatar
safeandsound
Default d1 procharger
hey this might nbe a stupid problem but need it gone i took my procharger off to change the oil in it and put it back on no it sounds like there is a bird under my hood.any idea's thx
Old May 2, 2012 | 09:16 PM
02402ramair's Avatar
02402ramair
Contamination on the belt more than likely. Spray some brake cleaner on the belt while it's running making the noise and if it goes away for a second the it's the belt making the noise. If it does not then look a little deeper such as a pulley or maybe blower. Bet it's the belt.
Old May 2, 2012 | 09:58 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
As long as it is filled back up with the Procharger oil and with the full 6oz you should be fine!
Do as stated above and start looking at the Belt - but just an FYI and you probably know already that Prochargers have that BIRDY whistle sound - now unless yours is more prominent than before after the oil change then there might be more to it -
But give the above stated a go first! and make sure the belt is as tight as before!
Can you make a video or sound clip for us? that will help us hear and see what you are!
Thanks,Matt
Old May 2, 2012 | 10:49 PM
safeandsound
THX WILL DO.playing with it thursday let you no.
Old May 3, 2012 | 10:25 PM
safeandsound
hey thanks for the help.come to find out one of the ribs on the belt was off one rib on the pully what a noise it makes you would never think something that small would make so much noise thanks again.
Old May 3, 2012 | 10:39 PM
madmatt9471
Very cool - glad you found and "NOW" a good piece of info for all of us!
Thanks,Matt
To d1 procharger
