Fuel help
Old May 8, 2012 | 12:38 PM
DrJer's Avatar
DrJer
1st Gear
Default Fuel help
Setup notes:
'97 Corvette Coupe
P1SC1 at 14lbs
427 stroker
mild cam
looks like it'll put 700hp to the wheels
Lingenfelter said a walbro255 with racetronix harness should work... it didn't
So we got the walbro400 and a msd voltage booster... still lost fuel pressure ????
Ordered the dual pump hanger, it is on the way...
Questions:
Do I hook up the walbro255 with racetronix as primary with the MSD to run the walbro400 under boost?
Will running 2 different pumps cause issues?
Run both together always?
Please offer some advice!! I wanna get this beast going finally!
Old May 8, 2012 | 01:24 PM
robert miller's Avatar
robert miller
Originally Posted by DrJer
Setup notes:
'97 Corvette Coupe
P1SC1 at 14lbs
427 stroker
mild cam
Questions:
Lose that MSD V/booster and get a kenne bell. The MSD one,s are junk they go out really fast. I have the stock pump then a ext/pump with the k.b. bop that only come on when in boost.
