retune
Old May 8, 2012 | 05:47 PM
Dave concrete's Avatar
Dave concrete
Default retune
Just a question, if my current set up consists of Novi 2000, meth, headers etc and I make 581rwhp now, and I went ahead and just install a blower cam with the presant tune what results would I achieve, or how would the existing tune work with the cam install? Would I gain some, or could I actually cause damage?
Old May 8, 2012 | 06:29 PM
racerrob333's Avatar
racerrob333
Yes u need a retune. Yes u could hurt your car. You have spent alot of money on your car dont skimp now
Old May 8, 2012 | 06:32 PM
Dave concrete
No not trying to skimp just that if I throw in a cam lets say tomorrow by the time I get it to Jersey for a tune just was wondering if damage could occur. Would damage occur driving normal or only if I lay into it?
Old May 8, 2012 | 06:50 PM
Milan's Avatar
Milan
You should be able to drive it no problem assuming it idles, etc. DO NOT floor it.
Old May 8, 2012 | 08:02 PM
Dave concrete
Wow I never would of thought there wasn't enough tune in the tune for a cam to run decent? I new it wouldn't be great just thought it wouldn't be optamized.
Old May 8, 2012 | 08:13 PM
Milan's Avatar
Milan
Depends on what your current set up is and how big your cam is. Most cams require much LESS fuel at idle, more RPM, more timing, sometimes airflow tricks, etc. etc.
Old May 8, 2012 | 08:42 PM
joshtownsend's Avatar
joshtownsend
Im betting it will run just fine, wot or not... Blower cams are usually not as big s NA ones.. If you have a wideband, just what it.. Remember, the tune on the car not does not sound like the OP did hit himself, so it was a "tuner" that did it, so im sure it was done on the super safe side anyways.
Old May 8, 2012 | 08:51 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
You would be able to drive to a shop to be tuned, but stay OUT of boost. You may have some bobbling idle going on etc, but you can get it to your destination.
You have a stock bottom end and your making a lot of power, there is no room for error.
Old May 8, 2012 | 09:30 PM
robert miller's Avatar
robert miller
Doug knows what he is talking about here. So for sure stay out of boost. Plus if the car is a stick car you will be better off keeping the car going over a auto at idle..
Old May 9, 2012 | 06:26 AM
Dave concrete
To a shop Doug or do you mean your shop Talk to you soon
Old May 9, 2012 | 09:16 AM
DOUG @ ECS's Avatar
DOUG @ ECS
I don't want to be presumptuous Dave.
To retune
