twin pump write up!!
Old May 9, 2012 | 08:33 PM
Boosted_C5's Avatar
Boosted_C5
Default twin pump write up!!
i searched and nothing came up. I need a write up for a DIY twin pump setup. i want both pumps in the tank running all the time.
Old May 10, 2012 | 03:31 PM
bearcatt's Avatar
bearcatt
Never found a complete writeup. However I've compiled some bookmarks during the course of my research.
Maybe others can chime in and provide a compete how-to and/or advise.
Fuel systems are not a one size fits all solution because there is many different options and needs.
Hopefully the myriad of links below will be at least little helpful.
http://realstreetperformance.com/sto...on-test-5.html
http://forums.corvetteforum.com/c5-t...ll-w-pics.html
http://forums.corvetteforum.com/c6-f...ump-setup.html
http://forums.corvetteforum.com/c6-c...uel-pumps.html
http://www.powertraincontrolsolution...ual_rev1.1.pdf
http://www.aacorvette.com/pdf/aa_fue...structions.pdf
http://forums.corvetteforum.com/c5-f...it-for-fi.html
http://forums.corvetteforum.com/c6-z...el-system.html
Old May 10, 2012 | 04:31 PM
1stGlance's Avatar
1stGlance
CF Senior Moments Member
A lot of the folks that run these have the second pump activated via a hobs switch - so it doesn't run all them time. It only really needs to come on when you put your foot into it - no all the time when your just cruising or normal highway driving....
I would suggest to call Lonnie - They / he - provides great support!
E-mail: Orders: Sales@LonniesPerformance.com
Tracking/Delivery: Support@LonniesPerformance.com
Tech Questions/Inquiries: Info@LonniesPerformance.com
Old May 10, 2012 | 04:52 PM
bearcatt's Avatar
bearcatt
I've heard great things about Lonnie too.
The hobbs switch seems like good idea.
What about using a good second external pump instead of two intank pumps, plus also upgrading the single internal pump.
I have the later style top mounted fuel system.
Old May 10, 2012 | 04:58 PM
1stGlance's Avatar
1stGlance
That works too -
( it will require drilling a hole in the tank for the second pump)
Old May 10, 2012 | 05:14 PM
bearcatt's Avatar
bearcatt
That works too -
I wish the late 2003+ Vettes had the side mount setup.
I found this ECS fuelblock video a while back.
http://www.youtube.com/watch?v=ZN6Kyaoyd6I&lr=1
Old May 10, 2012 | 05:32 PM
sabastian458's Avatar
sabastian458
I dislike having a pump come on at a set PSI, like say 2psi, and then cut off shortly after. To me that seems like adding an undue stress to the system let alone a shock of fuel to the rails at an off time. Even if you dont need all that fuel right then.
Having all the fuel ready means not having to tune arroud a super rich condition due to the spike in fuel volume/pressure, and then having to tune for when that pump shuts down. It would be a hole lot easier, and marginally safer, to tune for all the fuel at all the time. But that is my opinion and we are all intitled to have one.
My DYI fuel system will have both pumps all the time.
Old May 10, 2012 | 05:39 PM
bearcatt's Avatar
bearcatt
Would that spike in fuel show up in the air/fuel ratio on data-logs or a dyno. Just curious.
Old May 10, 2012 | 06:20 PM
CancerJCC's Avatar
CancerJCC
As long as the setup is, well, setup properly then everything is fine with a hobbs switch. If you have 58psi at the rail and the second pump kicks in and maintains 58 at the rail then no issue.
If you let the fuel pressure drop before kicking in the second pump then yes it would show up. The key is kicking it in while you still have constant pressure.
Old May 10, 2012 | 06:30 PM
bearcatt's Avatar
bearcatt
Thanks for answering my question.
Old May 10, 2012 | 06:54 PM
1stGlance's Avatar
1stGlance
you may change your mind later....
Old May 10, 2012 | 07:23 PM
Boosted_C5's Avatar
Boosted_C5
I currently have a 97/98 style setup with and Aeromotovile stealth 340lph, Kenne bell BAP, and aeromotive regulator. I just want to put another 340 in the tank. From what i have read so far i will need to ditch the BAP.
Old May 10, 2012 | 07:48 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
For a street car running both pumps all the time will eventually cause an over heating problem with the fuel on warmer days. You can actually hear the fuel boil in the tank.
A proper regulator should eliminate any spikes etc when the second pump kicks on.
http://www.eastcoastsupercharging.co...category_id=89
Old May 10, 2012 | 08:38 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
I have twin pumps in my car and have for years. Both run all the time. Down here is some of the hottest, most humid weather you will see and I have no issues. Not saying everyone will be issue free, but in my experience, it's been perfect.
Old May 10, 2012 | 08:39 PM
bearcatt's Avatar
bearcatt
Wow! Fuel boiling in the tank is crazy.
Old May 10, 2012 | 08:45 PM
bearcatt's Avatar
bearcatt
Maybe a racetronix or similar for less voltage drop ?
Old May 10, 2012 | 08:46 PM
bearcatt's Avatar
bearcatt
Which fuel pumps do you have installed in tank ?
To twin pump write up!!
Old May 10, 2012 | 10:14 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
that is how I ran mine, custom made with two LPE pumps, no BAP, 97-98 fuel setup run through an aero motive regulator, and 80# injectors, work fine in the Texas heat. I seldom let my tank get under 3/8 so plenty of fuel for cooling.
Old May 11, 2012 | 10:18 AM
Corvette-Chris
St. Jude Donor '08
Had 2 walbro 255's, now I have 2 Deatschwerks 300+ pumps.
LikePeter-Pan said, I don't let the fuel get too low, so I never worry about it.
Old May 11, 2012 | 11:14 AM
Boosted_C5's Avatar
Boosted_C5
Lol I let mine go till the low fuel warning comes on sometimes.
