Stall advice needed!
Old May 23, 2012 | 12:36 AM
huggerorange73's Avatar
huggerorange73
2026 Corvette of the Year Finalist - Modified
2025 C6 of the Year Winner - Modified
St. Jude Donor '12-'13
Default Stall advice needed!
Okay gang,
I'm sure sooner or later the stock trans is going to bite it, so I'm going to yank the trans as soon as I get back from Power Tour and have it rebuilt to handle the power from the blower.
Question is, which stall to put in? I was leaning towards the Vig 2800...here's what the car has in it :
3:15 gears
Ported Throttle Body
LS6 Intake
Texas Speed & Performance Long Tubes & Off Road mid pipes
Corsa Indy Pace Car Exhaust
A & A supercharger kit
Car puts down 515 RWHP /455 RWTQ
I'm running a set of MT 17" drag radials ( 275/40/17 )
What say you?
Old May 23, 2012 | 12:51 PM
corvettebob1's Avatar
corvettebob1
This one
Old May 23, 2012 | 01:03 PM
huggerorange73
This one
Thanks Bob!
Old May 23, 2012 | 03:59 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
I've got a 3000 Vig, with a 3.42 gear ratio. It all depends on how street able you want to keep your car. With a 3.15 gear I wouldn't go any higher then 2600 max at 2800 if you like it a little looser. The Vig run taller then the Yank. So a 2800 Vig maybe equivalent to a 3200 Yank.
If I had to do it over I wouldn't go over 2600, but that's my personal taste.
Old May 23, 2012 | 04:38 PM
huggerorange73
Just for giggles, I called Yank and Vig directly to see what they would recommend for the car.
Vig suggested a 2400 ( which works out to a 2800 ) and Yank suggested a 3200.
I'm still more inclined to go smaller than larger....
Old May 23, 2012 | 06:02 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I'm running a YANK 3200 with 3.42 gears and couldn't be happier -
I'm not too sure of the Vig 2400, even if it works out to be a 2800 - why not just state it is a 2800?
If you don't want a YANK then do a Vig 2600-2800 which would be like a 3000-3200 in their terms - sheeeeeesh! I hope that is right!
I will recommend the YANK in my behalf, customer service and product is very good! PLUS - a 3200 is a 3200 and a 3000 is a 3000 and a 2800 is a 2800 - you get the picture
Thanks,Matt
Old May 23, 2012 | 06:19 PM
huggerorange73
Thanks,Matt
Yank might be the way to fly.....I was just concerned that the 3200 would be too much for the car.
Old May 23, 2012 | 07:30 PM
Chris Stewart's Avatar
Chris Stewart
I started with a Vig 3200 triple disk, and was happy with it. I could footbrake to about 2K, anymore it would push thru the brakes. It felt mild in my opinion, so a year later I had it adjusted to 3600, and it goes a few hundred RPM higher. It's pretty aggressive now, especially on the street. Note it was a free complimentary adjustment available to all owners. It flashes exactly to the advertised stall, so I dunno what people mean with the funny rating.
Old May 23, 2012 | 10:47 PM
madmatt9471
It would work well - it's all in the STATER and the size on how well it performs in the so called 'Parking Lot Behavior' - and with the larger stater it behaves real nice -
IF the 3200 scares you at all then do a 2800-3000 - just call Dave at YANK and let him know.
Thanks,Matt
Old May 24, 2012 | 12:19 AM
a/c man's Avatar
a/c man
I'm running VIG 2800 3 disc lock up! drives stock every day on the street and runs 9s at the track! love it!
Old May 24, 2012 | 08:15 AM
Mike04's Avatar
Mike04
I've ran a vigilante 2800 and 2600 at your power level, I liked the 2600 best (3.42's). I'm still running a 2600 stall (triple disk now).
Old May 24, 2012 | 01:35 PM
huggerorange73
Keep the suggestions coming in!
Thanks for all the advice so far.
Old May 24, 2012 | 03:56 PM
optimum01's Avatar
optimum01
Vig 2600 here- its also what RPM trans said would work best w/ my 342 rear as I have a "street" car only 625 rwhp and I dont track it.
Old May 24, 2012 | 06:35 PM
TRIZ's Avatar
TRIZ
Have a 2600 stall TCS converter with 3.42 gears.
Still feels too loose for me.
Btw, Probably the cheapest way to fast track times is a high stall converter, like a 3800 or higher stall - undrivable for me though.
Old May 24, 2012 | 07:39 PM
2003VETT's Avatar
2003VETT
From: Still the Fastest (still running) Stock Bottom End Blown LS1/ 2010 ECS CC 10.50 CHAMP Hamilton, NJ
I started with a yank 3200, I now have a yank 3800. I liked the 3200 much better on the street...
Old May 24, 2012 | 07:56 PM
LV,99LS1VERT's Avatar
LV,99LS1VERT
Okay gang,
3:15 gears
LS6 Intake
What say you?
I'm running a Yank 3200 with good results....
To Stall advice needed!
