Methanol Injection Unit
Old May 24, 2012 | 10:32 PM
ex9850's Avatar
ex9850
Default Methanol Injection Unit
I bought a corvette with A&A SC and a Coolingmist methanol injection system. A gauge and min/max controls are installed where the ash tray was. I gather these controls are for the methanol system. Anyone know anything about them or where and how they should be set? I have methanol in the tank but not sure anything is functioning.
Old May 24, 2012 | 11:45 PM
regorih's Avatar
regorih
Take some pictures so member have a better idea as to what you are referring to.
Old May 25, 2012 | 12:32 PM
1320IN9's Avatar
1320IN9
Go to coolingmist web site and download the instructions for the controller, the min max ***** are to set the desired boost on off settings.
Old May 25, 2012 | 09:46 PM
ex9850's Avatar
ex9850
Greg taking your advice and contacting the Coolingmist people. Their website was not really helpful.
Old May 26, 2012 | 12:23 PM
1320IN9's Avatar
1320IN9
Click on instructions and click on the vc-2 PDF file and it's all right there on how to set The controller how you want it
Old May 26, 2012 | 07:33 PM
ex9850's Avatar
ex9850
Gregg - I do not have the vcII controller - I have the CMGS Controller and fail safe. Here is a picture of that unit. When I set min or max the gauge just returns to zero and reads 0.0 through the run.
Old May 26, 2012 | 10:24 PM
1320IN9's Avatar
1320IN9
http://www.coolingmist.com/instructions/cmgsfs.pdf
the VC-2 and the CMGS follow the same procedure to get it set up, that link will tell you how to use it, also there are youtube vids as well.
Old May 28, 2012 | 03:15 AM
ex9850's Avatar
ex9850
Greg - I down loaded the pdf file you linked to and it is slightly different than the one I was looking at. With the car running the gauge in the ashtray reads 0.0. When I adjust the min *** it moves as you would expect; but. quickly returns to zero. Then I set the max *** the same way and after a few seconds it returns the readout to 0.0 also, Then i get on the car pretty good but the gauge reads 0.0 all the way through. I am totally ignorant about the meth/water injector. The meth/water tank has fluid but the dyno hp has fallen about 50 hp.
To Methanol Injection Unit
