Catch Can Hose Spec?
Old May 31, 2012 | 02:07 PM
BlueTeamZ06's Avatar
BlueTeamZ06
Default Catch Can Hose Spec?
I'm looking at improving my catch can/pcv solution and want to run higher diameter hose to the can and fittings.
What is the spec of hose to be used? Any brand names/part numbers?
I've heard that it's a bad idea to use vacuum hose as the oil will eat through it eventually.
Thanks!
Old May 31, 2012 | 09:41 PM
JT FRC 00's Avatar
JT FRC 00
I replaced mine just to clean things up under the hood with power steering hose 3/8 100psi from Autozone. It was shipped to me with fuel line hose originally.
Old May 31, 2012 | 10:18 PM
undertaker's Avatar
undertaker
From: ECS : WTF did you break now and HTF did you break it this time
I'm using aeroquip -6 an fittings and lines for mine.
Old Jun 1, 2012 | 03:40 AM
BlueTeamZ06
That sounds really slick. Any chance you could post pics of that?
To Catch Can Hose Spec?
