ghetto tune
Old Jun 16, 2012 | 04:33 AM
reactor2's Avatar
reactor2
Default ghetto tune
So I installed my supercharger last year and haven't had the vehicle tuned yet. I rarely drive it and I haven't attempted full throttle. I do have a wide band installed so I can see my A/F ratio so I know its not lean.
I'm going to tune it when I have the chance to sit down and learn the software but that might be a while. Since I'm itching to feel the power could I potentially try it out using the following method?
I have a wet NOS system as well. Lets say I drop in the small NOS pill for atomization purposes and a large fuel pill to compensate for the extra O2 provided by the supercharger. My NOS trigger is set to activate at WOT.
As long as the WideBand reads at 11.5 or so I'm ok right? I don't plan on this being a long term solution. Like I said, I'd like a taste of the power. Works when the NO2 is supplying the O2, seems like it would work just the same when the supercharger is supplying the extra 02. Its kind of like a old-school carb guess your jet size tune.
Is that ghetto or what?
Old Jun 16, 2012 | 08:45 AM
02402ramair's Avatar
02402ramair
Yep that would be getto for sure and a good way to take out a ring land. You would also need the timing to be pulled back.
Old Jun 16, 2012 | 08:49 AM
SargeZ06's Avatar
SargeZ06
Why don't you just get it tuned? Take to Doug Rippie up there. He can take care of it.
Old Jun 16, 2012 | 09:28 AM
MMA FIGHTER2's Avatar
MMA FIGHTER2
A good tune is only 600.00 bucks come on now spend a lil money and do it the rite way.
Old Jun 16, 2012 | 10:23 AM
RaW Z06's Avatar
RaW Z06
Why chance running lean and damaging your motor
Get a good tune
Old Jun 16, 2012 | 11:59 AM
BLOWNBLUEZ06@RKT Performance's Avatar
Supporting Vendor
If you decide to try it, it'll be interesting to see how it turns out.
Old Jun 16, 2012 | 03:04 PM
p1bz's Avatar
p1bz
If you are boost referenced it is plausable. Nitrous is a constant O2 supply, boost is not. Its linear, less down low, and more up top. A better way to do it is with a FMU, like on the old mustangs. Boost goes up, and it pinches off the fuel return line and adds more fuel. Works just fine. Especially everybody these days with rich "safe" tunes. No better than a Carb in most instances.
Old Jun 16, 2012 | 03:31 PM
Skunkworks's Avatar
Skunkworks
Much more to a tune then just AFR... I'd say you'll be kicking yourself in the rear, sooner then later (much sooner).
Old Jun 19, 2012 | 12:04 PM
2bridges's Avatar
2bridges
not frowning - but you seriously going to try to "learn" to tune on a supercharged w nitrous - GOOD LUCK BRO! you will need it
Spend your $500-600 and get a professional tune and enjoy the car
Old Jun 21, 2012 | 05:10 PM
jmoody66's Avatar
jmoody66
Default Agree
Sorry but I have to agree. Risk a $5000.00, to replace an engine, to save $500.00?
Old Jun 24, 2012 | 09:19 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
reactor3??? new username after the meltdown
Learning new things is good, it keeps the brain happy; slow and steady wins the race..........don't go all in on pocket dueces
Old Jun 24, 2012 | 10:23 PM
p1bz's Avatar
p1bz
Lol, awesome post.
To ghetto tune
