Fuel getting hot
Old Jun 21, 2012 | 03:42 PM
Sebring98's Avatar
Sebring98
Default Fuel getting hot
Ive got a 98 coupe, with the very early vortech setup (which mounts the SC on drivers side). My fuel system consists of FAST 60 lb injectors and a lingenfelter (i believe 225 lph) fuel setup. This was professionally tuned. I am running about 4-5 psi of boost, car runs great. I have open tracked and auto crossed the car several times this year, sometimes with back to back heats because my wife and i run the car in seperate classes. I have been having problems with the car "overheating" the gas in the tank. Case in point, we were at Putnam park in indiana a few weeks ago, and she ran right after i did. We noticed a "foghorn" sound coming from the car as it ran. upon further investigation, it was the fuel tanks, i slowly removed the gas cap, and ALOT of pressure was released. Also, one could feel that the fumes coming out of the tank were very hot. This has happened again last weekend after a single day auto x event. Does anyone have any idea what is causing this?
Old Jun 21, 2012 | 04:42 PM
stevieturbo's Avatar
stevieturbo
Fuel gets hot from two things ( ignoring ambient heat )
The pump itself, and getting fed to a hot engine bay/rails and then back to the tank ( if it's a return system plumbed that way )
As to what temperature it needs to be before there is a problem, that's still open to debate. But pressure in the tank is quite normal on a modern car.
You would need to establish what temperature the fuel is, before you can actually say it is a problem.
Ive tested on my own car, although generally weather here is pretty cool. Ive never seen any temperatures that have caused me concern when the engine and pumps are running.
Although I do run a cooler on the return line, the cooler is very badly located and wouldnt have great airflow.
Old Jun 21, 2012 | 04:43 PM
1redz06's Avatar
1redz06
I'm shooting in the dark here, but I'm thinking your evap solenoid is at fault. Check engine light on?
Old Jun 21, 2012 | 04:47 PM
stevieturbo
True, if this isnt venting the tank, it would allow excess pressure to build.
Old Jun 21, 2012 | 07:41 PM
Sebring98's Avatar
Sebring98
stevieturbo
yea its a return style system, 97-98 cars were that way. And no, im not getting any check engine light at all, but it seems like its building an awful lot of pressure in the tank. also the vapors are literally hot, you can hold your hand in front of the filler neck and its hot enough you dont want your hand there long!
Old Jun 22, 2012 | 04:14 AM
stevieturbo
Again, not a very scientific or proper way of determining if it is a problem.
There may or may not be, but you'd need to carry out some work to find out for sure.
Old Jun 22, 2012 | 09:32 AM
BLOWNBLUEZ06@RKT Performance's Avatar
Supporting Vendor
You need to put a gauge on the evap line or something to gather accurate data. So far, you're assuming that you have pressure, when in fact you could have vacuum in the tank. I understand the hot vapors and the expansion from that, but it could still be vacuum from evacuating the fuel from the tank so quickly during your races.
Old Jun 22, 2012 | 03:13 PM
corvettebob1's Avatar
corvettebob1
Hot fuel has been a known problem for a long time even back in the C4 days.
Why do you think they put a warning on the cap to remove it slowly?
I would bet the foghorn sound you heard was the tank venting itself through the evap solonid.
97&98 were unique in the fact the PCM controls the vent.
Old Jun 22, 2012 | 03:24 PM
Steve@RSD's Avatar
Steve@RSD
St. Jude Donor '13
I experienced this EXACT thing last year on a road trip.My Coupe is a 98. The pressure was SCARY!!! not just a whisp but mine shot hot fuel out at me. The fuel pump was screaming because the fuel was just vapor.
It did it all day one day and I just kept stopping and topping off the fuel trying to keep it cool.
It has not done it since and I think the return system was to blame and was constantly circulating fuel and heating it up. Perhaps a stuck return regulator valve at the fuel rail, I don't know.
I bet you could change that return regulator valve on your fuel rail and fix it, I have gone to a complete RSI Dual pump setup so I never figured mine out, but it was BIG pressure, I was afraid for the plastic tanks and my own life.
Good luck fixing it.
Steve
Old Jun 22, 2012 | 04:22 PM
stevieturbo
So what controls the vent on other cars ?
Pretty much every modern car Ive seen the ecu always controls a small solenoid to re-circulate/vent fuel tank vapours via a charcoal canister back into the intake.
I cant think of any that dont, as pretty sure it is a legal requirement as far as emissions go.
Nothing has been routinely vented to atmos for years.
Old Jun 22, 2012 | 07:54 PM
Skunkworks's Avatar
Skunkworks
Yup looked at that PID before, don't remember exact values, but think anything over 1/2 throttle and duty cycle was 100% or damn close.
Old Jun 22, 2012 | 08:00 PM
stevieturbo
Normally they vent somewhere around mid throttle and full throttle.
Although...depending on exactly where they vent, a boosted setup could mess that up as when the OEM ecu opens the solenoid, there could be boost in the intake tract, so it would never be able to vent.
It might be ok on a light use daily drive
But on a race car that sees a lot of boost for extended periods...it's feasible the tank may not vent for some time, or could even have boost applied to it ( although it is via a very very small pipe )
Old Jun 22, 2012 | 08:24 PM
Skunkworks's Avatar
Skunkworks
The evap solenoid PID is not something I look at regularly, think last time was 2 or so years ago. It is more aggressive than your description… Anything (within reason) above idle and I seem to recall duty cycle going up. May be I’ll scan it this weekend.
A slightly pressurized tank is what all my corvettes had on hot summer days, well at least when I went to fill up (yes supercharged).
Given the age of OP's setup, wonder if it couldn't be as simple as a plugged inline filter and vapor pressure issues with hot fuel?
Old Jun 23, 2012 | 04:03 PM
corvettebob1
Well there you go......I should have looked into it myself instead of taking my tuners word for it when he upgraded my PCM to 2002.
Unless my memory is failed me he told me ther was no place to pin the wire to on the new PCM.
One would think a simple ball check would be more reliable and less expensive then an electric solenoid.
Old Jun 28, 2012 | 09:51 PM
Steve@RSD's Avatar
Steve@RSD
St. Jude Donor '13
Did ya find a problem? High volume pump and a return system will do that......
To Fuel getting hot
