will a 325/45/17 fit under a untubbed z06
#41
![](/forums/images/ranks/1k-2k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Only have about 800 miles on them. Can't even tell they've been used. I don't do a lot of miles but treat them pretty bad. For the street u will need the roll out of a 28" tires. These tires will better then anything I've found.
#43
![](/forums/images/ranks/5k-6k.gif)
![](https://sphotos-a.xx.fbcdn.net/hphotos-prn1/614614_10100923731845939_1103619909_o.jpg)
Here is the 325/45/17 Racemaster on an 11" wheel.... Its ALMOST just a little too narrow for an 11" wheel... This one looks pretty damn good but you can tell the tire is "pulled out" some on an 11"... Notice even with the side walls perfectly flush or even maybe pulled out a bit, the contact patch is still not all the way to the sides...(probably a little too much air in them but...) Goes to show that extra rim width doesnt always improve contact patch...
I think the ideal rim size for the 325/45/17 Racemaster would be a 10"....
I'll soon be ordering up a set of these for some 9.5" C5Z wheels like 69LS6.... Following his lead....
![Big Grin](https://www.corvetteforum.com/forums/images/smilies/biggrin5.gif)
#46
