Drag radial which tire size for A4 3.42gears
Hi
i´m thinking what would be smarter tire size
295-50-16 (28") or 275-40-17 (26")
both are hoosier drag radial tires
i´m thinking this for AUTO whith 3.42 gears , and both NA and spray in mind
i would think bigger is better but maby they are tuff for the NA power
i already have M/H 26X11.5X16 DOT and Hoosier 28X11.5X16 but there are few races here where i live that only allow radials so i´m gona buy the 3rd pair
Baezi
Baezi
Former Vendor
when i hit the 1/4 mile i will have the dot slicks under
145-147 are the plans
thanks
Baezi
Received 1,762 Likes
i had a 1.6 60ft and 11.1@124 with a set of 315/30/18 R888 set at 18 lbs. filled back up to 30lbs drove home and still have them on my wheels. oh leaving on a 150 shot
Thanks guys
excelent infos
i´m gona use the less taller tires
appels to appels
MT drag radial ll 315-35-17 VS. Hoosier drag radial 275-40-17
what would you vote for here same height of them both 25,8"
baezi
excelent infos
appels to appels
baezi
MT 295/45/17 its 27'' fits just fine and will hook better i never could hook a 275/40/17
Going to see what a new set of Hoosier 28x14.5 x16 will do in BG KY... Those are some nice time and 60ft also with those tires. Hope you get to come over man.. Robert
275s suck with more than 500rwhp!!
Thank you Robert I'm learning what works without tubing On a auto a radial works better if you go with 17s the 295/45/17 works awesome! The 275s just spin and don't hook don't waste your $ on them unless you have 500rwhp or less now 16'' wheel is better with a 295/50/16 more sidewall that's where I'm going next for more traction after Brett's new tune its blowing off tires now the car spin's all the way through the 1/4 its scary and Bret tells me stay in dont let off ***** so I can log a full pass and tune her scary!!
what gears do you have and what power level ?
Baezi
