Shifting issue... clues?
Old Aug 5, 2012 | 04:31 PM
HvyHitr's Avatar
HvyHitr
Default Shifting issue... clues?
Ok I just finished my auto swap and the car seemed great. At first I though it felt a bit funny taking off and maybe it was just me having not driven a car with a big stall in it for awhile (3600). Then I realized it was starting off in second gear. Now you can put the shifter in first gear and it will leave in first and all the gears are there. But if its in any other gear it leaves in second.
Checked the pin out of the pcm, checked the shifter cable.
Its real hard to tell but its does feel like once in a while it goes from first to second almost the instant you move. Like its shifting to fast from first.
Any ideas?
Old Aug 5, 2012 | 05:18 PM
BLOWNBLUEZ06@RKT Performance's Avatar
Supporting Vendor
Any ideas?
Got HPtuners?
Email me your tune and I'll help if I can.
Old Aug 5, 2012 | 08:49 PM
02402ramair's Avatar
02402ramair
Who tuned the car for the auto swap. hook up some tuning software and command 1st, 2nd, and so on to find out if the ECM can command each shift. If it does then it's more than likely in the tune. If it can't then it's more than likely in the wiring. Make sure you have the ground wire for the Trans grounded.
Old Aug 5, 2012 | 10:02 PM
HvyHitr's Avatar
HvyHitr
Im pretty sure its in the tune. Im going to put it one the shop computer tomorow and check the solenoids. ECS changed it to auto for my and keep my orignal tune. Doug said it would need to be tweaked after install. Just figured it may need some fuel changes but I guess it may need some shift tweaks too.
Bret do you do anything with EFIlive?
Dale
Old Aug 5, 2012 | 10:34 PM
Supporting Vendor
Dale
I'm not set up for working with EFI live. If Doug tuned it, he'll figure it out for sure.
To Shifting issue... clues?
