what gains are made by removing the A&A dongle and.......
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
going with a straight 4 in with filter? Im wanting the low profile rad so I can maybe raise the cradle back up and alos heard there were gains to be made
![Smile](https://www.corvetteforum.com/forums/images/smilies/smile5.gif)
nfantbabyjesus (11-19-2019)
wow, that might be my next mod! Gotta love free hp. Did you have to retune for that?
Did you guys use the Dewitts low profile rad? Anything else I need to know to do this? What fans are you running too? Like to keep the stockers but dont see that happening.
yes retuned/stock rad.I cut my cradle and layed radiator down some and installed a 4'' inlet on supercharger.stock fans
![Frown](https://www.corvetteforum.com/forums/images/smilies/frown5.gif)
I have no dyno proof but my car did not pick up any power from this mod. The only gain I got is my boost curve shifted left by 400 rpm. So basically I started building boost 400 rpm sooner than I was before the mod.
![](/forums/images/ranks/3k-4k.gif)
What $$? guess it depends on what you are starting out with. If you are looking at this mod and including the Rad in the $$, ok - maybe not... But if you are simply changing the inlet pipe, that is pretty cheap...
When I converted to a single intercooler, I lowered the stock radiator... I am still running the gen 1 procharger bracket, etc.
I am running a 3.85 pulley at the moment (been since day 1) - I have a 3.7 on my bench, but I have not put this on as I think it will result in belt slip. Knock on wood, I havent had issues with that with the 3.85 (I do have a riechard pulley, the 3.7 is not).
I am currently pushing ~570 and havent made any changes in a few years... was just looking for a little more, just to get me over 600 and been debating the following:
-Change out my 3.5" pipe to 4" for SC inlet
-Flip Intercooler around to shorten piping from SC to IC.
Not sure if I need to do both, or just do both to get it out of the way. I am hitting 10psi as is, I guess worst case, if I feel I am pushing too much, I could just put on a restrictor plate.
Thoughts?
John
Thoughts?
John
I had the original style procharger inlet chocking off my F1A.
It went from 17.5psi to 20.8 psi (@6600 rpm) just by doing the dewitts rad/4" dongle. Car picked up so much extra power I needed IDS 1000 injectors and a retune.
We spun the ***** to 7k rpm and she made 21.4psi!
![](/forums/images/ranks/5k-6k.gif)
It took 2 of us to get that damn thing on. Neither one of us thought it would work then bam good to go!
Im a little nervous right now because I used a the thin maf coupler.
I would like to see pics of what people have done though.
