Whats the best intercooler LIQUID or AIR
Hi guys I have a vortech Liquid to air intorcooler that came with my vortech. Supossidly these are better because the discharge piping to and from the cooler its shorter so it better responce. But most corvette kits come with air to air. Should I sell this intercooler which would go above the engine and use about 2 feet of piping and plumbing coolant. And buy an in front of radiator tpe and use no coolant just cold air and 4 feet or so of piping.?
That original Vortech setup is not the way to go. The water gets heated up and never recovers.
Your question is loaded. For the track, liquid is better. You can ice it down for each pass. For the street, air to air is better because it doesn't get heat soaked so easily. It'll be more consistent.
Received 1,272 Likes
2016 C5 of Year Finalist
A&A has a well designed intercooler. I bought his system just
for the intercooler. I run the Vortec SC.
ie, if either setup is too small to deal with the heat and airflow, it will always be a bad system. Wouldnt matter with water or air.
I'd just say that A2A is simpler, lighter and less to go wrong. And cheaper too. Although it does require space to be found at the front of the vehicle for a suitably sized core.
Air to air is the simplest. No leaks or heat soak. Run a little meth under boost and you'll be happy. I use the A&A latest intercooler and it allows plenty of boost and air flow to the radiator.
Godspeed fmic
I like the air to air style better anyway. I was pretty much dead set on selling this intercooler. I dontlike that the intake air will always be in the 200 degree range. At least with air to air its what ever the outside temp is and cooler because of highway speeds. The next question is if I find an intercooler with 2.5 inlet and outlets would this be sufficient. I found a nice god speed one with a blow off valve location. Theres also a WRX one for sale that could tuck away nicley infront of the radiator has anyone tried this?
Cruise-In VII Veteran
others, take a look at the A&A IC cores form the past year or 2, I don't know the 'type' or manufacture for the core material, but it's not your typical 'rolled fin' you see in a radiator or IC from years past
