opinions on new build
Trying to get some opinions on an engine build. In yalls preference what would be the parts of choice for my ls1 based engine. basically needing help determining the whole rotating assembly .I plan on using a set of 317 heads ive had setting in my garage in combination with a stage two blower cam from arun.
what crank,rods,pistons etc would you guys prefer,and what power levels would you think could be acheived by doing this?
btw , ill be running the a&a v2 headunit
ISIS SUCKS FAT CHOAD
Callie's crank (LSx or even better dragon slayer) Callie's Compstar rods with ARP bolts, wiesco pistons with GFX or hellfire rings, ACL, or king bearings, ARP main studs and that should be stout enough to pretty much do what you want on a ultra high performance street car. Even some mild to moderate racing stuff.
The above rotating assembly has been in the 8's in the 1/4 and well over 1,000 WHP time and time again.
Good luck!
Good luck!
Former Vendor
