Roller rockers/ springs with vortech S/C
Hi Guys Im thinking of adding roller rockers because since my car is 15 years old im sure the valve springs are weak. No good for a supercharged engine. I want to go with a good dual spring set up, Comp cams makes springs. I figured since I was in there mind as well do roller rockers. Is something like 1.8 ratio good or dont even bother with them and keep stock rockers?
awsome. Heres a dumb question though. Wouldnt it make more sence to get shaft mounted roller rockers which are cheaper to buy then just upgrading the stamped stock rockers?
Arun the master has spoken.................. and spoken wisely.
