Why 5 and 7
Old Aug 28, 2012 | 05:57 PM
ttz's Avatar
ttz
Default Why 5 and 7
Why is there the trend of cyl 5 and 7 blowing before any of the others? Do they lean out more due to manifold design or something else?
Old Aug 28, 2012 | 06:45 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Yep.
Old Aug 28, 2012 | 08:04 PM
ajrothm's Avatar
ajrothm
That is the Million Dollar question that know one knows the answer to.... But damn sure on LS1/LS6s, #5/7 will be the ones to go....
Some think it has something to do with coolant circulation issues and steam pockets in the heads around those cylinders.... Some think it is due to intake manifold design.
You don't seem to hear about the 5.3s lunching #5/7 NEAR as often/common as LS1s/6s.
Mine killed #5/7 with a good tune, meth and only 10 psi.
But hey, "stock motors are good for 700hp" so.......
Old Aug 28, 2012 | 08:31 PM
SBCGENII's Avatar
SBCGENII
"The intake on the LS1 or LS6 when reversed (installed like the front wheel drive) still burns up #7 first. The intake can be flipped with 10 02 sensors and the afr on each cylinder/bank does not change within the error of the sensor.
Kurt"
Copied from another forum.
Old Aug 28, 2012 | 10:36 PM
robert miller's Avatar
robert miller
That had to hurt... Robert
Old Aug 29, 2012 | 01:41 PM
stevieturbo's Avatar
stevieturbo
Nope, only possible reasons are coolant related. It has nothing to do with the intake.
Old Aug 29, 2012 | 03:06 PM
user_name's Avatar
user_name
The 5.3's suffer the same fate along with the gen4's. Regardless of the fact that the Achilles heal of these motors, it is detonation occurring on #7 that kills it. I've always gone overly conservative on my tunes knowing that #7 isn't nearly as happy as the dyno, knock sensors, wb say the engine is.
My stock motor was good to 750rwhp.
I don't know why it is always #5 and #7 though. I don't think anyone does.
Old Aug 29, 2012 | 03:16 PM
stevieturbo
Well Ive blown engines, and seen other blown engines. And it certainly is not 5/7 every time.
There may be a higher proportion, but it is not limited to them
And unless you're listening for knock on a per cylinder basis, and monitoring EGT and AFR on a per cylinder basis, you will never truly know how happy cyl 7 is.
You're just taking an average of either each bank or all 8 depending on how much you're monitoring.
Old Aug 29, 2012 | 03:23 PM
user_name's Avatar
user_name
I'm aware of this. I'm just taking other people's misfortune to help myself here. I've seen these motors let go since ls1's first came out. Nitrous was the big power adder back then, and everyone thought it was due to bad distribution starving the rear cylinders. Then people ran direct port kits with bigger fuel jets on #7. It helped, but in the end #7 was still the one to get hurt more often than not.
Of course it is not always the #5 or #7, but it is the majority. Any shop willing to admit to the engines their customers have popped that were tuned by them would tell you that. :crickets:
To Why 5 and 7
