Pre-Blower Meth?
Old Aug 29, 2012 | 11:10 PM
Robert 2000's Avatar
Robert 2000
Default Pre-Blower Meth?
I have heard of guys doing 3 nozzle meth setups with a nozzle pre blower. How are the results from this? Can it be done with a 50/50 mixture? Boost juice in particular because that is what I run. Does the 100% meth damage the blower or would boostjuice? This is my biggest concern. Also, where does the meth sprayed pre blower ultimately endup.
Also, can it be done with a snow meth kit? I know I know I don't have the alky control/ECS kit I may switch down the road.
I can't find a whole lot on this searching.
Btw my car is A&A Si trim kit if it matters
Old Aug 30, 2012 | 06:08 AM
stevieturbo's Avatar
stevieturbo
If you have a while....
http://www.aquamist.co.uk/vbulletin/...read.php?t=251
At a lower level where you arent pushing the compressor hard, I cant imagine it being any real benefit.
If you are, then it may be.
The liquid itself wont do the blades any harm if done correctly, although methanol itself may cause some deterioration over time.
A friend in the UK with a ProMod car that tuns methanol had his wheels hard anodised for durability as they spray a lot of meth pre-compressor as well as injecting as normal into the intake ports.
Ive only recently started spraying some myself, but I also spray pre TB as well. So it will be hard to judge any results.
I just figure any additional cooling it can offer can do no harm, and it seems cooling a compressor at this early stage when pushing the compressor very hard can improve it's efficiency
Old Aug 30, 2012 | 10:01 AM
BLOWNBLUEZ06@RKT Performance's Avatar
Supporting Vendor
I was spraying pre compressor but never did any pre/post testing. Not sure if I'll be doing that with the new F1X setup yet.
Old Aug 30, 2012 | 10:21 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Lose the boost juice, straight meth is the answer... (IMO)
Old Aug 30, 2012 | 12:00 PM
Robert 2000
Did you notice any damage done to the compressor from this? That is my main negative concern.
My tuner wasn't comfortable with this. I am using the snow kit and they want a meth/water mix. He was not crazy about putting 100% meth under the hood having another combustable chemical under hood.
Old Aug 30, 2012 | 12:02 PM
Robert 2000
Makes sense I may be pulleying down maybe I will reach the point where this can do some good I think I will be very close to max rpm if I do pulley down. I am currently 3.6 pulley on Si may go down to 3.4.
Old Aug 30, 2012 | 02:01 PM
stevieturbo
I got a little fitting waterjetted out to fit a nozzle pre-compressor. The jets Aquamist use are much smaller and neater than anyone elses, so dont take up much room within the inlet tract.
After a little grinding and filing
Old Aug 30, 2012 | 07:52 PM
TRIZ's Avatar
TRIZ
I ran preblower meth for about 3 yrs on A&A S-trim with 3.0" Reichard Ultra-grip.
Never noted any degradation on the impeller. Traded it in to Andy and he didn't find anything wrong either.
The preblower setup yielded little.
About 1 psi increase above 6k rpm as I recall; couldn't tell any difference unless I was pushing it hard. On the street I couldn't see any difference; No traction at high rpm.
On the strip I saw the 1 psi improvement at peak rpm.
Logged boost on HPtuners.
As noted earlier: use only if you're looking for every last ounce of power.
Good Luck!
Old Aug 31, 2012 | 01:16 PM
Robert 2000
Very cool that looks like a clean setup
Good Luck!
Well thats good to hear
Do you think a 3.4 pulley would be swinging the blower hard enough to see any benefit?
Old Sep 3, 2012 | 12:46 PM
Robert 2000
Bump
Somebody has to know more on this
Old Sep 3, 2012 | 02:42 PM
stevieturbo
The thread I linked is over 40 pages long with some very good info on it. There are other threads on the forum too.
What specifically do you want to hear about it ?
Old Sep 3, 2012 | 04:04 PM
Robert 2000
Oh wow i read the posts in this thread but didn't go back the link. I will read up there.
Nothing in particular just wanted to hear more success or horror stories with this I didn't realize how little this is done at least on this forum.
Old Sep 3, 2012 | 04:10 PM
stevieturbo
I guess most dont do it as they just stick with injecting pre-TB which works very well.
But most turbocharged methanol cars Ive seen place injectors before the compressor as well as after and of course close to the intake valve.
So they too are doing it to help cool the compressor and also intake charge
There is some good stuff in the link, so it is worth taking the time to read through it. Some guys have more data than others.
But there arent really any negatives that I can see. Positives...harder to measure if you're also injecting pre TB, but the placement achieves two different things
Pre-TB is about cooling the intake charge, but you're also aiming to cool the combustion chamber too.
Pre-compressor is all about intake charge cooling and helping the compressor do less work which means IC has to do less work, the setup can work better.
Old Sep 3, 2012 | 05:11 PM
Mike04's Avatar
Mike04
I'm running a 3 nozzle Alky Control setup. M3 pre SC and a M10 and M15 after the intercooler. I added the pre SC to try to drop my IAT's. Didn't notice much of a change in IAT and never dynoed before and after. No negative so far running it. I think I need a bigger intercooler more than adding the extra nozzle.
Old Sep 3, 2012 | 09:29 PM
TRIZ's Avatar
TRIZ
Mike,
Ran the same size jets exactly with the S-trim.
Didn't notice AIT drop but boost was up about 1 psi peak only.
I think you have to get outside of the compressor map sweet spot to get the most benefit...
Never noted any negative impact.
Yea, Heard u had a small intercooler unit (and adding the extra nozzle didn't work)!
Old Sep 3, 2012 | 10:16 PM
Mike04's Avatar
Mike04
Mike,
No slack around here
Old Sep 4, 2012 | 08:30 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
I think 3.48 vortec would be enough and you would see power.
Old Sep 4, 2012 | 10:30 PM
Robert 2000
Ahhh okay well if no one is seeing damage to the blower impeller I may give this a shot. And I know I am very far from needing a bigger intercooler but I guess you can always find a weak point.
Makes sense but it can't be a lot of time or money to rig this up so I don't see why more people don't try it the meth is already there and setup just need to hook another nozzle.
Thanks this may happen down the road along with a head swap
Old Sep 5, 2012 | 02:52 PM
stevieturbo
I guess they dont try it because pre TB works very well anyway.
To Pre-Blower Meth?
