High elevation gear change
Old Sep 26, 2012 | 07:52 PM
EZ2BEVILC5's Avatar
EZ2BEVILC5
Default High elevation gear change
Hey,
I did another post a while back asking about torque loss from going from a 3.42 to a 3.90 with a 6 speed. I realize that you lose torque and some of that seat of your pants acceleration because the car is moving along easier with the higher gear ratio. However, I am also at 6000' and I am wondering if the car is losing additional torque due to the loss of oxygen. meaning when approaching high RPM it is more effected by the loss of oxygen then the 3.42. It is a stock engine with an A&A kit. It just doesn't seem as fast as it used or should. It dynoed at 500RWHP at sea level. I estimate 425-450RPM at 6000'.
Any help is appreciated.
Old Sep 26, 2012 | 08:14 PM
2bridges's Avatar
2bridges
That is a significant elevation difference
expect aprox .5psi drop for every 1000' of elevation
That is 3lbs - roughly 75whp - you most definately will notice that seat of the pants.
The solution = pully that bitch down some more to make the additional boost you want
As for gearing change - I personally would not consider going deeper than 3:42
Old Sep 26, 2012 | 08:55 PM
7LitreC5's Avatar
7LitreC5
You lose a huge amount of power at altitude. The rule of thumb is 3% per 1000 feet. I live at 7350 feet and the power difference between here and sea level is amazing.
Part of the problem is that you make less boost at altitude. When I had a SC on my car it made 8psi in Tempe but only 6.5psi here.
To High elevation gear change
