Best Nitrous controller
Old Oct 6, 2012 | 03:00 PM
play's Avatar
play
Default Best Nitrous controller
Need help looking for a good nitrous controller c-5 drive by wire.
Tryed nitrous express not much luck got any good ideals
thanks jim
Old Oct 6, 2012 | 07:58 PM
tirecraft's Avatar
tirecraft
http://www.lingenfelter.com/mm5/merc...gory_Code=C163
Old Oct 6, 2012 | 08:40 PM
ProEFI's Avatar
ProEFI
Supremacy 1 car at a time
I'm running HSW microedge nitrous controller and I love it.
Old Oct 6, 2012 | 10:05 PM
Rob Petyo's Avatar
Rob Petyo
^^^ I'm taking mine out soon and going with a zex. I wonder what one of these is worth as a good deal ...
Old Oct 7, 2012 | 02:17 PM
Triton4C's Avatar
Triton4C
I have a NOS launcher controller and it's worked perfect so far. Tried playing around with it at the track to ramp in the power and it did exactly what it needed to. Only thing I don't like about it is when you are using the ramp in feature you aren't able to see the in between rpms so all you see is the begining rpm and end rpm....you have to basically guess what rpm your ramp in points are in between if that makes sense. It's easy to still use but would love if i could see all the rpms across the board.
To Best Nitrous controller
