OK I have a fuel pump? I'm running a kenny bell boost a pump on my c6 z06 stock in tank pump because its a 2004 c5 when I upgraded to a YSI I added a 2ND fuel system its aeromotive A1000 with a -10 line taped into the gas tank like A&A kit does now my ?? is what should I do with the boost a pump!! leave it as is boosting the in tank pump? or remove it? or boost the A1000 2ND system??
If the BOP is hooked to the A1000 when in boost leave it hooked to that.. I sure wouldnt chg it up when it is working great and you know it is...Our motors are about the same and I am only running the A/A fuel system about 1100.00 for everthing with the 40amp kenne bell BOP on the car. Working great from day one..Robert
No problems I'm just worried the boost a pump will burn up my in tank pump and its a 2004 c5 you have to pull the transmision out to replace the pump
Pulling the cradle dont worry me any more. I think dealing with putting a new pump in the tang making sure ever thing there was correct would be worse to me.
No the kenny bell is hooked up to the in tank pump not the A1000
No.big probloms with the fuse holders having a loose connection and flaming up.When I used one I installed fuse and crimped the connection for it.That's a lot of amperes through some small wires.
True I had a msd bap before this KB and it melted the fuse holder too!! so u think the in tank c6 zo6 with the hot racetronic wire kit and the A1000 is good? wonder what the limits would be like this car dynoed 900rwhp but my trap speed says less
I'm making 850 or so now with a lpe pump in tank and a 255 external with boost reference.pressure don't drop on dyno.
You dont need to drop the trans to get to the stock pump. Its in the tire well. 30 min for me to have it out.
OP has a 2004.
03.5 and up have the same fuel system as a C6. Please be careful what you post up, someone searching in the future could come across the post and become misinformed.
That is true about some of the BOP but the Kenne Bell never had that problem that is why guys where pulling the msd one was bad for it.
Originally Posted by Milan
OP has a 2004.
wrong I have a late model c5 takes a drive train pull to change my fuel pump!!
that sounds good but I'm not really sure how much hp I'm making u say your @ 850rwhp and u trap 135-138mph with a stick they trap higher and my dyno was 900rwhp and I trap 143-145mph with my auto now with that said some of the guys on here say I'm only @ 750-800 rwhp because of my trap speed I have seen my car make 10 pulls in the last year all over 900 so I'm afraid to unhook the BAP if that's true It may be the help my fuel system is surviving on
OP has a 2004.
well said keep facts straight the 2003-2004 suck to change out the fuel pump
Its all good brother were just all trying to learn more and help a brother out! sometimes we may know the answer but need to hear it from other members before we try it
I'm trapping 143 with other pulley.hope to trap 146-148 this week.
