nitrous install ....
1. I have not removed the schrader valve and hooked up the attachment to the fuel solenoid will is affect driving at all or should i just go ahead and remove the schrader valve and hook up the lines?
well that's the only question i have for now. but any feed back would be greatly appreciated.
Now for the good stuff..
The noids
Another view
This is where i pulled the power from
The bottle bracket dont mind the sippy cup lol
The bottles
Charles
I believe so sir , I took that picture befor I got the attachments to hook up the nano lines.
Beer I have that bottle opener however I got it used and it looks like the wires were just cut by the previous owner, are those connected by weather pack connecters or spade connectors ?
Thanks guys I'm going to get some more work in the car Friday night and I'll put up more pictures then.
I've never worked with weather pack connecters, but i realyl like that idea of keeping everything clean, is there a special type of weather pack i need to look into?
while i push the bridge down....
I've talked to vararam and tried moving the maf to the bottom and using the longer coupler but that wasnt much help either, i just figured i'd save the plate install for last.
Charles
WOT switch
the noids moved up (much easier to connect the fuel line)
Where i will be pulling power for the switch panel
will this work for the fpss placement? im going to use the other side of the swivel mount for a fuel pressure gauge.
Now the only question i have it what fuse can i tap for the switch panel, i remember reading on here about:
fuse 11 hot when acc or on
fuse 7 hot permanent
fuse 22 switched hot
If i had to chose one i'd go with 11 or 22 but can any confirm or deny this?
Also can i run one power (lets say for my arming switch, then piggy back the power off that to my purge & bottle opener? or do i need three separate power supplies ?)
Well that's all for last night i'm going to get a lot more done tonight hopefully i can complete all the wiring and mount my nitrous gauge as well.
Thanks again guys
P.S. I know i need to clean my engine bay is dirty i plan on cleaning up everything
Got the purge hooked up
Ran the wires from the switch panel to the trunk for the remote bottle opener
Did some work on the hvac
Well that's all I have for now, also I went fuse number 22 for the power to switch panel, it's a spare and I figured if the radios guys use it why couldn't I? Also does any one know a good spot to put my ground wires near the radio ?
Never mind i found out that i can use one of the bolts next to the ignition for a close ground... thanks guys ill get alot more pictures up tonight or tomorrow morning, i should be wrapping this car up and start driving it this weekend.
Power to the switch panel
The ground i used for the switch panel..
The remote bottle opener i had laying around..
Thanks again guys.
Charles
Wires ran to the back for my nitrous gauge
everything installed except the window switch
finally got enough room to make the nitrous plate fit without cutting a bunch of stuff up
And don't be worried i'm going to modify the radiator cover shroud so my power duct will fit.
Ohh one more thing, i ordered a longer purge line because the one they send you is too short for my setup, once i get everything hooked up im going to tuck and hide all the wires.
