Too lean on nitrous
Intake only 02 z06
Hsw plate
Nx stage 6 lightning solenoids
Nx window switch
Lnc2000
Tr6 plugs
3000psi nano kit
.046 .028 jets
Aem wb02
Equal length lines from solenoids to plate
I've been working on the kit and the wiring for the last week or two. Took it out last night to test it out.
When the kit comes on at 4k Afr jumps up to 14.5-14.7. Got out of it the first time. Tried it again thinking it was just a lean spike and after about 1.5 seconds it starts breaking up I think. It kinda sounds like a rev limiter.
Upped the jet to .031 same thing happens. Then again on a .035.
Does this soynd like a specific problem to anyone. I didn't get much into diagnosing it last night. I'm wondering if I have a clogged fuel line to the plate or maybe fuel solenoid not opening.
Any other suggestions
Intake only 02 z06
Hsw plate
Nx window switch
Lnc2000
Tr6 plugs
3000psi nano kit
.046 .028 jets
Aem wb02
could be your are maxing out your fuel system and loosing pressure
Baezi
Just because your wideband shows that you're lean doesn't mean it's true.
You could easily have cylinders dropping out due to ignition problems and they often won't show up until your cylinder pressure rises on the nitrous. A cylinder that doesn't burn the fuel will make the wideband show lean on the entire bank and make you think you need more fuel. When you add fuel, the car runs worse. Work to identify the true problem.
Bottled closed and system on the afr pegs at 10.0. So the fuel side is working.
I have went over wiring and checked the lnc again.
Changed to a 50 shot
31/18 and the car ran good. A little leaner on the afr then I liked. High 12s, no breaking up.
75ish shot
38/24 ran great Afr was high 11s low 12s
85-90?
41/26 no breaking up, but high 13s afr
How do I calculate what shot im doing, from the nitrous jet or the fuel jet? With the nano my nitrous jet is smaller then the standard size.
I want a 100 shot, so I'm thinking a 28f and 44n
75ish shot
85-90?
running the test if the fuel solenoid is firing, but you need to know that your fuel system is capable of supplying the necessary volume and pressure while you're on the button. I would recommend redoing the test while getting some fuel pressure readings at the rail and doing it with the fuel jets you plan on using for the shot you're going to be running.
75ish shot
85-90?
At the Nitrous Express website they have a jetting chart broke down by vehicle.
I'm running a 150 shot and am using a 62n and 36f on a single nozzle system.
do you have a pressure gauge on your bottle...or a bottle warmer....I'm wondering if your bottle pressure is spraying too low and your fuel levels are to high for the amount of NOS your spraying, that, combined with projection tip plugs that have the effect of advancing the timing may be throwing things off.
I thunk his fuel to nos mix is off and his plugs are'nt burning everything right.
the fuel jet probably seems big, but its because of the nano.
trying to tune again tonight, i've got dual widebands now so i can monitor both banks.
Before you do anything else, read this write up:
http://www.yellowbullet.com/forum/sh...d.php?t=415202
