Battery relocation
Old Oct 19, 2012 | 09:20 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Default Battery relocation
Any cheap clean easy solution to relocating my optima yellow top battery to one of the side compartments in the trunk. I saw the LPE conversion but would rather not have to spend the 400 on it.
Old Oct 19, 2012 | 09:41 PM
02402ramair's Avatar
02402ramair
I bought cable and ran it down the tunnel, put battery in compartment. 125.00 done!
Old Oct 19, 2012 | 09:42 PM
02402ramair
I did a disconnect switch also but that's extra
Old Oct 19, 2012 | 09:45 PM
MVP'S ZO6's Avatar
MVP'S ZO6
Would u mind posting some photos?
Old Oct 19, 2012 | 10:02 PM
02402ramair
Old Oct 19, 2012 | 10:34 PM
4DRUSH's Avatar
4DRUSH
Kris, where's your alternator cable?
I don't see it, should be on battery or battery side of cut off switch.
Old Oct 19, 2012 | 10:45 PM
02402ramair
It's not hooked up in that pic. I put starter back on to spin motor over to check short block. It has just battery wire now for power. There is a alt wire from big lug on alt to big lug on starter. I also have cable from starter big lug to fuse box power lug to supply fuse box.
Old Oct 19, 2012 | 10:55 PM
4DRUSH's Avatar
4DRUSH
But if you're switching the power to the fuse box, the alternator will still feed the fuse box from the other direction.
Alternator has to go to battery or battery side of cut off to kill power. (separate cable)
Old Oct 19, 2012 | 11:06 PM
4DRUSH's Avatar
4DRUSH
When the cut off switch is off, the only live power in the car will be from switch to battery & battery to alternator.
There is a 3 prong cut off switch out there, that also kills the power to alternator, not sure who makes it.
I think I used no 2 welding cable for the power & no 4 welding cable for alternator to battery.
Old Oct 19, 2012 | 11:15 PM
02402ramair
When I turn off the switch I have zero power to alt and car. All connections are made at starter like factory. I did not see a reason to run a new alt wire to back of car. Is there? My alt feeds the fuel pumps for higher voltage also.
Old Oct 19, 2012 | 11:18 PM
02402ramair
I did 0 gauge for battery to starter.
Old Oct 19, 2012 | 11:26 PM
4DRUSH's Avatar
4DRUSH
Alternator makes power (when it turning) no need for battery power to fuse box.
Nothing will shut off if alternator is linked to fuse box, must go to battery or battery side of kill switch by itself so the kill switch can kill that power also.
Old Oct 19, 2012 | 11:37 PM
4DRUSH's Avatar
4DRUSH
Guess that's better, I forget all those sizes
Best way to feed big fuel pumps with rear battery,
Connect 8-10 ga to switched side of kill switch, proper sized fuse block, 50 or bigger relay near pump with trigger wire to ecu or switch panel up front
Old Oct 19, 2012 | 11:44 PM
02402ramair
I see what you are saying now. In event the car is running and needs to be shut down. Took me a minute. Lol
Well crap!
Old Oct 19, 2012 | 11:53 PM
fotoboy's Avatar
fotoboy
Well crap!
Yup, won't pass tech.
Old Oct 20, 2012 | 02:09 PM
jhaines's Avatar
0jhaines
Former Vendor
Default Battery kill
Shouldn't pass tech but I see battery disconnects wired like that all the time so they must be getting past tech somewhere. You can hit the kill switch if the car is running and it won't shut off. A lot of people test it the other way around - car off and it won't start but that isn't the same thing.
Old Oct 20, 2012 | 03:03 PM
4DRUSH's Avatar
4DRUSH
If tech doesn't check the cut-off switch when car is running, I guess it will pass.
Main goal of cut-off switch is to kill motor & fuel pump from outside the car in case of emergency.
If you wanted to cut corners, you could just kill the fuel pump or kill power to the pcm at the ignition switch, which would kill the motor & fuel pump.
Not the best way of doing it because of the remaining live wiring, which could ignite spilled fuel, etc.
I took it a step farther & installed an interior lever/cable that adapts to the rear cut-off switch so I can turn everything off from the driver's seat or rear of car.
http://www.jerrybickel.com/batteries...t-1330013.html
Old Oct 20, 2012 | 03:28 PM
digivex's Avatar
digivex
Last time Tech checked mine, they told me to start the car and leave it running. The guy also had me hold my hands up so he was assured that I wasn't turning off the ignition or killing the car internally when he hit the kill switch.
I must look like some kind of deviant to be told that
But, I guess some people don't change the alternator wiring and try to sneak through tech by turning off the car when the guy hits the switch
I've never seen them turn the switch with the car off and then tell the driver to try to start the car. They're more concerned with killing it when it's running - From an intelligent / safety perspective
To Battery relocation
