Electronic boost controller
Old Oct 21, 2012 | 10:33 PM
flash of red's Avatar
flash of red
Default Electronic boost controller
Can you read vacuum and boost from the turbo compressor housing for your EBC IN port? Is there only boost and no vacuum at the turbo compressor housing? Currently not getting a vacuum reading on my EBC. I previously used a port from my intake with my previous turbos that did not have ports on the compressors.
Old Oct 22, 2012 | 07:42 AM
stevieturbo's Avatar
stevieturbo
Vac/boost readings should only ( edit...can only ) be taken between the throttle and intake valves.
Old Oct 22, 2012 | 10:04 AM
flash of red
I thought so. Precision told me the ports on the compressor housings were for the lines for wastegate control and was the most accurate place to access but they probably thought I was running the wastegates directly without an EBC. I will get the lines rerouted correctly.
To Electronic boost controller
