Lean to rich help
Old Oct 22, 2012 | 07:24 PM
ttz's Avatar
ttz
Default Lean to rich help
As some of you may recall, I recently swapped in some 750cc injectors. I had many issues getting them set up since there really is no data on them. I've gotten it down for the most part. My current issue is when you start the car (even once up to temp) it will idle around 16:1AFR then over the course of about 1 min or a little less, it slowly comes down to being rich at 13.2:1 This is all at idle. During driving is great and it keeps a steady 14.6:1 but any time under about 12% TPS and it goes back to the 13.2:1. What table would change this in HP Tuners (either issue, but I'm mainly concerned with the way it starts lean and progresses to rich.)? Ive tried playing around with some of the afterstart enrichment tables but they didn't seem to do anything at all, so either I didn't change them enough of I changed the wrong ones. Any ideas? Thanks.
Old Oct 24, 2012 | 11:30 AM
ttz's Avatar
ttz
All the great DIY and pro tuners in here and nobody has any ideas?
Old Oct 24, 2012 | 11:52 AM
fotoboy's Avatar
fotoboy
Hp tuners has a forum
Old Oct 24, 2012 | 11:59 AM
ttz's Avatar
ttz
Yes they do, but there only seem to be a small handful of people on there willing to help anymore. I posted on there and usually all I end up with is questions or comments that don't come remotely close to answering the original question. Not sure what happened to that forum but not many seem to want to help fellow hobbyists anymore.
To Lean to rich help
