Finally did it.
Nov 3, 2012 | 08:45 AM
Finally did it.
Most of you know my build.347 cube on 21lbs now with the bada$$ stage 3 cam from CCP.This is the first time out with 15" wheels and my new rts wheels with the little 8.5 hossier slick.First pass out mph 149.All the rest of the pass my charge pipes blow off.I'm happy to get the 9s.This car will go 9.5s easy @152 or so.BTW got a 1.43 60 foot on a 8.5 slick.Big thanks to you guys that helped on my build.
http://www.youtube.com/watch?feature...&v=8qgA9sqV7z8
Nov 3, 2012 | 08:55 AM
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Really nice!
Got a little squirelly on you - but you held it together - there is definitely more in it!
What size front brakes you running with the GTO front runners?
Thanks,Matt
Nov 3, 2012 | 08:56 AM
Quote:
Originally Posted by
madmatt9471
Really nice!
Thanks,Matt
stock.Just the z06
Nov 3, 2012 | 08:59 AM
69ls6
stock.Just the z06
Okay cool!
I have the C6 Z51 up front and thought if you had the same I'd check into what you did!
Nice runs again!
Thanks,Matt
Nov 3, 2012 | 09:47 AM
Congrats Ricky!! Unbelievable performance! With a stick no less!
Great driving and great MPH!
You are actually running the MPH that it should for the HP (which is rare these days)
Excellent job on the car and driving!!
Nov 3, 2012 | 10:05 AM
Nice runs bro I am interested in your wheel setup you have there.
Nov 3, 2012 | 10:43 AM
Damn!!!!!! Thats some rowing for sure!!! Good job.
Nov 3, 2012 | 10:46 AM
Badass runs and great driving..
Congrats
turbo402
gto spares up front with 1.5" spacers and a lg 15 spindles with rts 15x9.33 on a 6.5bs. rear tires are the c11 compound 26". 26x8.5x15
Nov 3, 2012 | 10:48 AM
Thanks alot guys.never figured a little 347 would run like it does
Nov 3, 2012 | 10:52 AM
69ls6
6.5 backspacing? i thought they would stick out more than that. any pics?
Nov 3, 2012 | 11:00 AM
algZO6
there 9" wide...when u put 10" wide u need a least 7.5bs...When u look at rts wheels there tell you that rims are 9.5 or 10.0".By their specs all wheels are made .33 wider,so 9 inch is really a 9.33 and a 10 is a 10.33
Nov 3, 2012 | 11:01 AM
Nov 3, 2012 | 11:03 AM
doing work Ricky.... Congrats on the 9.7, you was driving the wheels off it...
Nov 3, 2012 | 11:05 AM
69ls6
thanks for the info. 15s with the spindles and bead locks is going to be my next mod and am still trying to figure out what b.s. to go with since i have the tpe fenders. congrats on the runs!!!
Nov 3, 2012 | 11:18 AM
Simply BADASS Ricky!!!!!
It's been a long time coming, told you those little 347's work!!!!
Nov 3, 2012 | 11:26 AM
Thats awsome! Whats the drivetrain consist of? I see it's c6z, but any tube or output shaft mods? T56 or 6060? Clutch? Great driving for sure.
Nov 3, 2012 | 11:39 AM
Nice driving, cool vid, 9.5's for sure, congrats.
Nov 3, 2012 | 11:41 AM
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
Insane!! Congrats!!!
Nov 3, 2012 | 11:48 AM
slow ride
tr6060 stock from 09 c6z,diff has hardened 300mm stub shafts [500mm] some say.stock torque tube,mcleod rxt clutch,stock axles
