bye bye motor
Old Nov 30, 2012 | 12:13 AM
  #61
BLOWNBLUEZ06@RKT Performance's Avatar
Supporting Vendor
Originally Posted by user_name
4032 mahle powerpak pistons here
I don't agree that they are "totally unacceptable" at all.
I genuinely mean it when I say that I hope you don't ever find a reason to retract that statement.
Old Nov 30, 2012 | 09:17 AM
  #62
slow ride's Avatar
slow ride
You can get a .015" over also if needed, but it will be custom.
As for the powerpak mahle's there is a guy over on yellowbullet making around 1000 on some 383 flat top ones also, but we all know it's pushing it. I'd guess the flat top style is going to be stronger around the top ring than a heavy dish. Again, not ideal, but better than factory for sure.
Old Nov 30, 2012 | 09:39 AM
  #63
turbo402's Avatar
turbo402
He should be boring the block today we want to keep it around .010 I dont know anyone that has bored an aluminum one .020 and boosted it with long lasting results. So we will see what happens.
Old Nov 30, 2012 | 10:50 AM
  #64
user_name's Avatar
user_name
That makes 2 of us
I've got some cheap scat rods in there too. We'll see how it goes. I tune awfully safe, and I don't think those pistons are too much of a risk under 1000hp not anywhere close to detonation. Look how well stock ones hold up. Nobody knew what they could hold until lots of people started trying. All the research I did on these found all the people popping them detonated or had no idea if it detonated b/c they didn't tune it themselves or check plugs.
You definitely get what you pay for, but on this site there is tendency to overdo it and suggest that is the only way to go IMO.
Old Jan 19, 2013 | 09:20 PM
  #65
turbo402's Avatar
turbo402
New motor is done its a lq4, 317 heads, 234 236 612 lift 115 lsa cam, je pistons hellfire rings raised the comp ratio to 10:1 did my 93 octane street tune today 11.0 afr 11 deg timing 13 psi, e85 tune 18 deg timing 11.8 afr. I will dyno it next week.
