failed e test help
Old Nov 26, 2012 | 10:10 AM
nitrouspaul's Avatar
nitrouspaul
Default failed e test help
01 vert with 377 twins 227 227 cam chasing my tail on this. when i try to tune for less hc on curb idle test my co goes up on loaded test
tried so far.
with air pump without air pump,no diff. leaning tune in open loop letting closed loop run test see dilution very close,retarding timing in cells that are in use during running of test, and finally running 1 gallon of meth with 1/3 fuel in the tank. this is what you see in the photo. i am close but feel that my cam is a bit big and maybe i will never win. any idears here? maybe i will wait until the new year and wait for the readiness monitor test that is coming and forget about trying anymore, needless to say the car runs better now that i have been trying to narrow the results for this test. i am running stock cats with 45k on them
http://s213.beta.photobucket.com/use...00000.jpg.html
Old Nov 26, 2012 | 03:08 PM
tlove32's Avatar
tlove32
2 things.....
1 - What's the LSA on that cam? Zero or negative overlap is key to passing tailpipe emissions. 227 on a 114 lsa is easier to pass than 227 on a 110 lsa
2 - 45k mile stock cats behind twin turbos are probably shot and in need of replacing
Old Nov 27, 2012 | 01:24 AM
SBCGENII's Avatar
SBCGENII
Try Arun or champion. They probably can help.
Old Nov 27, 2012 | 03:05 AM
Pekka_Perkeles's Avatar
Pekka_Perkeles
Try increasing End of Injector Timing with 5% and see what it does. It's under Fuel/General/Injector Timing/Normal if you're familiar with HPT.
Also, let it idle at 990 rpm, not lower, if that's fine with your local emissions laws..
Old Nov 27, 2012 | 08:11 AM
BLOWNBLUEZ06@RKT Performance's Avatar
Supporting Vendor
Not sure what plugs you're running, but put in some TR55's for the test and gap them at .040. Stay out of boost while running them. Test all of your plug wires for high resistance and replace any that show high. Turn your idle speed up, drive the **** out of the car on the highway to get the cats hot and working at their utmost efficiency, if you're MAF tuned, make sure you have no vacuum leaks, Changing your timing too high or too low will affect your HC's. If they'll allow it, run your VCM controller and push your timing up and down to see if you can bring it down. Don't use absolute timing values, rather the plus minus so that your adaptive idle spark will still remain in play. The EOIT change may help as Pekka mentioned, but consider pushing it both ways. Spraying fuel on the back of a closed intake valve might help it atomize better and create a more effective idle burn. You can try a Seafoam treatment . There is also a product that I've personally seen work called RxP fuel emissions reducer. Give that a shot while you're at it.
Hope this helps.
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
Old Nov 27, 2012 | 09:34 AM
nitrouspaul
the lsa is at 114
they wont let me play with tune while running the test as it is a timed test logged into the ministry main server while it is running.
my plugs are tr6 wires good how do cats go bad? i was running idle at 1150
To failed e test help
